best b16a turbo?
Old Oct 2, 2007 | 08:53 AM
iheartmyh0nda's Avatar
Default best b16a turbo?
hey everyone, i have undergone my turbo setup, and wonder what turbo i should get...
my goal: 280whp w/ stock block
330+whp not a stock block
im leading towards the t3/t4 57 trim turbo, does anyone have any info about this turbo?
or... what else is out there that is better or will spool up quicker?
thx ht
Old Oct 2, 2007 | 10:20 AM
carrnut21's Avatar
pm mike@synapsemotorsport, he was very helpful when i was picking out my turbo for my stock GSR.
Old Oct 2, 2007 | 10:44 AM
DeleriouS25's Avatar
Default Re: best b16a turbo? (iheartmyh0nda)
if your going to do just 350-450hp then just get a 57/60 trim from garret. you can get 350whp on a stock motor. go to evans-tuning.com they have hundreds of them
Old Oct 2, 2007 | 05:48 PM
Schister66's Avatar
Man U FTW
go w/ a 57 trim .63ar....if you have more to spend, PM The Shodan about the GT3251e. Its basically a variation of the 57 trim but it will spool faster. If money is no option, the GT28rs would be an excellent choice...then again, its $1300 after all the water lines and whatnot...
Old Oct 2, 2007 | 07:40 PM
update, now i have to go with a 5 bolt compressor turbo, where does that put me? what turbos can i get now?
Old Oct 2, 2007 | 08:00 PM
archull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyh0nda &raquo;</TD></TR><TR><TD CLASS="quote">update, now i have to go with a 5 bolt compressor turbo, where does that put me? what turbos can i get now?
Why do you have to go with a 5-bolt exhaust housing???
They really suck as far as flow rates go.
What manifold are you using?
I would suggest that you get the Garrett GT2871 with a full 3" DP and 3" exhaust
Old Oct 2, 2007 | 08:02 PM
PSI2HI's Avatar
Former Vendor
Default Re: best b16a turbo? (archull)
57 trim
Old Oct 2, 2007 | 09:36 PM
Schister66's Avatar
Man U FTW
Default Re: best b16a turbo? (PSI2HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSI2HI &raquo;</TD></TR><TR><TD CLASS="quote">57 trim </TD></TR></TABLE>
you would say that wouldnt you?
Old Oct 2, 2007 | 09:38 PM
PSI2HI's Avatar
Former Vendor
Default Re: best b16a turbo? (Schister66)
Used them for years w/ great success for that power application.
Old Oct 3, 2007 | 10:30 AM
do the t3/t4 57 .63 come in 5 bolt exhaust?
idk what to do now, do they really suck, or just not as good as top notch ones?
its a cast iron manifold
Old Oct 3, 2007 | 11:05 AM
PSI2HI's Avatar
Former Vendor
5 bolts cost more $$, no reason to go to one unless you have to, but they are available.
Old Oct 3, 2007 | 11:27 AM
riceball777's Avatar
gt3071r will spool quick and make the power you want
you only want to run t seris turbo if you cant afford gt turbos
Old Oct 3, 2007 | 12:45 PM
gunnerman's Avatar
Default Re: best b16a turbo? (riceball777)
great turbo...almost bought that one for my evo....makes good power without too much lag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">gt3071r will spool quick and make the power you want
you only want to run t seris turbo if you cant afford gt turbos </TD></TR></TABLE>
Old Oct 3, 2007 | 02:05 PM
Boosted Chemist's Avatar
Yeah but you can get a brand new t series for 550 bucks lol
Old Oct 3, 2007 | 03:01 PM
Schister66's Avatar
Man U FTW
Default Re: best b16a turbo? (Boosted Chemist)
Yeah but you can get a brand new t series for 550 bucks lol </TD></TR></TABLE>
and that $550 57 trim is going to make just as much power as the GT-R series on a stock engine....spool difference will be almost negligible. Not to mention, you'll have another $7-800 to spend on other things if you dont buy the GT-R series
Old Oct 3, 2007 | 03:45 PM
tegdude227's Avatar
then y do people buy them ? not being smart at all just asking for myself cause i wanted a 3076 myself but alot of people said just get the 60 trim from what everyone says you cant tell the diffrence untill you get into bigger turbos
Old Oct 3, 2007 | 04:20 PM
Schister66's Avatar
Man U FTW
Default Re: (tegdude227)
The GT3076R really is a great turbo in certain applications. In my opinion, it is used in more situations than necessary, but i'm not the one paying for it so i dont care.
The GT3076R basically allows the user to have a turbo that spools like a 57 trim, but is capable of 500 something wheel horsepower. The maps on Garrett's GT-R series are basically elongated versions of turbos like the 57 trim meaning it has a broader range of efficiency AND is more efficient at higher pressure ratios. Also, a common misconception is that the efficiency is attributed solely to the BB CHRA which is incorrect. The combination of an efficient CHRA and the wheel design is what makes the GT-R series as potent as they are. Simply put, adding a BB CHRA to a non-BB turbo is not going to allow it to spool faster. The only benefit is going to be the gain in transient response which cannot be measured on a dyno to my knowledge.
For those who dont want a run-of-the-mill T series turbo, there are other options available provided you care to look. I started looking around when i bought my new setup. I was recommended to The Shodan of STC who helped me tailor a turbo to MY setup. I chose the GT3255b which is a variation of the T3/T04E 57 trim. It is a non-BB GT series which is the "missing link" between Garrett's T series and GT-R series.
Go ahead and elaborate if necessary
Old Oct 3, 2007 | 06:07 PM
crowder13's Avatar
just go 57 trim, the only flow difference between 5 bolt and 4 bolt is not that much. now if uwanted to go baller u could go v band but blah blah blah. 57 trim is the way to go. ball bearing turbos might spool 2-300 rpms faster at the most. 57 trim should give u a good powerband and flow well too. no reason to spend all that money on a gt series turbo. its jsut stupid. precision makes really nice turbos too. and cheap also
Old Oct 5, 2007 | 12:52 AM
urnotfast's Avatar
Default Re: (crowder13)
i have a t3/t4 57trim on my 99 si and it feels grat im getting ready to get tuned looking for 325whp
Old Oct 5, 2007 | 06:35 AM
morgan@synapse motorsport's Avatar
Default Re: (carrnut21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carrnut21 &raquo;</TD></TR><TR><TD CLASS="quote">pm mike@synapsemotorsport, he was very helpful when i was picking out my turbo for my stock GSR.</TD></TR></TABLE>
always glad i could help.
330+ could be had with a 50 trim and a stock block, what are your ultimate power goals? 330+ if very vague, is it more like 400 450?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">then y do people buy them ? not being smart at all just asking for myself cause i wanted a 3076 myself but alot of people said just get the 60 trim from what everyone says you cant tell the diffrence untill you get into bigger turbos </TD></TR></TABLE>
definately not true, there are GT series turbos sized for just about every application, there is no mystery voodoo guessing game going on here, they're just better spooling turbos relative to their power potential.
Old Oct 5, 2007 | 07:08 AM
Mag00n's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Go ahead and elaborate if necessary </TD></TR></TABLE>
had that turbo on one of my old setup did not care for it at all
Old Oct 5, 2007 | 07:52 AM
slow96coupe's Avatar
I had a precision sc50 and it spooled good and put down 347 on a stock motor
Old Oct 6, 2007 | 10:32 AM
Default Re: (slow96coupe)
the GT30r is the best thing to go with for that car/setup, plus its pretty big so that if you wanted to build the block/head you could get around 550 with that turbo on high boost and c16.
i am going with the PT67 - 30psi here i come!
Old Oct 8, 2007 | 10:14 PM
187Chor's Avatar
GT2876R
buy it
NOW
b16a4
Jun 25, 2007 03:51 PM
TriK
Jan 30, 2003 11:26 AM
