Boost issues! need help...
Old Oct 3, 2007 | 02:29 PM
jorge59la's Avatar
Default Boost issues! need help...
I recently switched out my flywheel and my clutch, and after i received my car i noticed that i was putting down only 4 psi/ to the normal 8-9 that i had before.
i took out my manual boost controller, and i still get the same psi.
can it be my wastegate?(external) but if it was broken i shouldn't have any boost at all.
-can it be a leak? maybe a small hole somewhere. i did notice that my BOV is not blowing off!
help......
Old Oct 3, 2007 | 02:55 PM
Schister66's Avatar
Man U FTW
start by checking the obvious things first...vac lines, couplers, etc
Old Oct 3, 2007 | 06:19 PM
lovey408's Avatar
Default Re: (Schister66)
yea sounds like a coupler might be loose or a charge pipe isnt on properly.. happened to me once and thas wat HT members assumned and they were right
Old Oct 4, 2007 | 02:54 PM
jorge59la's Avatar
Default Re: (lovey408)
so i figured it out. It was a loose coupler and air was escaping from it when the pressure increased! -so i tighten it and everything is wonderless (for now)
thanks fellas.
civic-8442-
May 21, 2008 10:35 AM
LST2
Nov 15, 2005 10:09 AM
turbotime
Sep 26, 2005 06:22 AM
integ2
Jun 15, 2004 06:44 PM
93TurboSi
Oct 16, 2003 06:04 PM
