Automatic LS Turbo ??
Old Oct 3, 2007 | 06:46 PM
Peruviann83's Avatar
Default Automatic LS Turbo ??
i want some more power in my dc and my friend told me why not throw a turbo in there
i wanted to find out if there would be any problems running it in a fully stock ls motor and tranny just replaced both few months ago both have 40 k on them
Old Oct 3, 2007 | 06:48 PM
Schister66's Avatar
Man U FTW
i'm not up on the strength of the auto trannies, but it depends on your power goals...IMO, the easiest way is an Auto=>Manual swap and boost
Old Oct 3, 2007 | 06:51 PM
Default Re: (Schister66)
yeah i was thinking bout going manual but i use this as a DD and ij ust want more power on the freeway i just want a small boost nothing to crazy
what do you guys recommend ??
Old Oct 3, 2007 | 07:02 PM
Blown90hatcH's Avatar
Default Re: (Peruviann83)
No problem. I have converted some OBD2 auto LS cars to OBD1 and tuned them on Crome.
Old Oct 3, 2007 | 07:03 PM
bigbadboy's Avatar
not sure how much power u could make safely on the tranny but i would think 200-250 would be easy on the tranny. the motor is good for 300-350. maybe u can look up wat you can do to upgrade the tranny with. turbo+ AT= hard as launches and no missed shifts.
Old Oct 3, 2007 | 08:53 PM
Default Re: (bigbadboy)
how many psi's u think i could run without messing up the tranny or anything really ? is it worth puttin a turbo in a auto ?
Old Oct 4, 2007 | 01:28 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peruviann83 &raquo;</TD></TR><TR><TD CLASS="quote">how many psi's u think i could run without messing up the tranny or anything really ? is it worth puttin a turbo in a auto ?</TD></TR></TABLE>
the questions is how much hp/tq can the tranny hold before it takes a poop, the answer is i have no idea... i know the sohc auto's suck!
Old Dec 3, 2007 | 04:27 PM
liquidx's Avatar
sry im bumping a thread from the past i just want more input on this subject matter
Old Dec 3, 2007 | 07:54 PM
R1ce's Avatar
Default Re: (liquidx)
i did in my integra, the tranny was strong it would spin the tires if i wanted it too, the tranny lasted over 2 months then blew and just swapped an itr into it. it was pretty cool because i still had PS A/c and ect, and beat alot of cars
Old Dec 3, 2007 | 08:07 PM
fireman mike2288's Avatar
honestly u just want alttle more power for commuting???? dont turbo it save the money and just do header intake and full exhaust u said all u use that car is for cummte i mean if it was ur everything fun car then boost it but no point on a DD just DC header AEM intake and full exhaust and ull be fine
Old Dec 4, 2007 | 07:37 AM
liquidx's Avatar
see i dont want a little power i want like to reach around 225 or so all that i/h/e i've had before and took it off.......but question with turbo auto.......any large amount of lag since its automatic? how much could a rebuilt tranny possibly cost?
Old Dec 4, 2007 | 08:08 AM
Redcoupe's Avatar
I don't know about you guys, but around where I live, people practically give away automatic b-series transmissions. I've had one for 2 years sitting in my garage that I've been using as a table. They are easy to come by.
I would think 7psi on your average t3t4 would be ok on a auto trans.
Old Dec 5, 2007 | 01:03 PM
liquidx's Avatar
Default Re: (Redcoupe)
hmm what type of manifold should i use to keep ac.....and ps...im also guessing i might have to take off my abs too....i've been researching and think i might go along with this...expect to see a build thread
Old Dec 5, 2007 | 02:39 PM
93CX's Avatar
Yeah, go for it, but its still going to be slow and shitty. Also, either get the largest possible transmission cooler or a few extra LS trannys, because they're going to go every couple of weeks if you drive the car a lot.
Old Dec 5, 2007 | 09:41 PM
project dc2's Avatar
Default Re: Automatic LS Turbo ?? (Peruviann83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peruviann83 &raquo;</TD></TR><TR><TD CLASS="quote">i want some more power in my dc and my friend told me why not throw a turbo in there
i wanted to find out if there would be any problems running it in a fully stock ls motor and tranny just replaced both few months ago both have 40 k on them </TD></TR></TABLE>
you mike leungs friend ?
Old Dec 16, 2007 | 12:28 PM
spideymangDC4's Avatar
Default Re: Automatic LS Turbo ?? (project dc2)
bump for this, i wanna see how this goes
Old Dec 16, 2007 | 01:19 PM
HiProfile's Avatar
Default Re: Automatic LS Turbo ?? (spideymangDC4)
Auto trannies aren't cheap to rebuild, since not many people do it, and you really need OEM parts. The trannies aren't in big demand, so its probably cheaper to just buy & replace.
If I was to do this, I'd get something like a 60trim T3, a 50trim t3t04e, or a s-trim t3/t04b - all with a stg3 .63ar exhaust if possible. I wouldn't go more than 7psi with any of them, as thats ~250whp at the least on a manual, which would be about ~215whp with a slushbox.
I almost want to try the auto in my '91 LX when I put the obd1 stuff back on, but I already have the swap items & its a direct swap. I'd almost hate to ruin it, as the tranny shifts hard like my firebird's th350 w/B&M stg2 shift kit.
Old Dec 16, 2007 | 04:24 PM
blwn95civic's Avatar
i wouldnt turbo my dd... dd's are supposed to be slow lol that way when you drive the other car it seems that much faster but if you did turbo the car it wouldnt be near as reliable as it is right now. with all the money you put into a turbo setup and tune you could build a high comp. na car and still drive it everyday with out any issues about shreddin the trans
Old Dec 16, 2007 | 04:37 PM
m R g S r's Avatar
Default Re: Automatic LS Turbo ?? (trav95civic)
my single civic is deff gettin boosted.....merging on the highways sucks as does passing lol
Turbo beaters FTW
Old Dec 16, 2007 | 04:40 PM
rorik's Avatar
There have to be some companies out there that build import fwd trannies, like maybe level10? I would actually Prefer a strong automatic and a higher stall converter over a manual in a turbo car. (esp in something like a wrx, with awd) The shock loads under shifting would be less, the boost would build more quickly because of the converter, and your launch would be better. Basically, all the power would be more easily controllable, right there under your foot. I say look for a company that builds these trannies up, and go for it.
p.s. Why would you have to remove your abs? You wouldn't.
s_carey
Aug 6, 2007 08:28 PM
CORI
Sep 13, 2005 07:35 PM
1998teg
Sep 29, 2004 08:49 PM
meatball01
Dec 19, 2002 03:50 AM
shpae
Aug 26, 2001 10:05 PM
