Oil pump for LS Turbo?
Old Oct 2, 2007 | 05:15 PM
lsturbo*'s Avatar
Default Oil pump for LS Turbo?
I have a 98 LS motor that is being completly rebuilt and I need an opinion on my stock oil pump. I am aiming for the 350+ HP range so will the stock pump be good enough? The clearances are on the worn side, so I would like to at least replace the rotors and relief spring. However, I can't seem to find this offered from Honda. Other option is to buy a new OEM pump for $100. Does Honda offer the rebuild kit? If not stock/or aftermarket pump?
Old Oct 2, 2007 | 05:18 PM
bootlegcivic's Avatar
Default Re: Oil pump for LS Turbo? (lsturbo*)
Just buy a new OEM pump. We all use them for much higher HP goals than that.
Old Oct 3, 2007 | 12:00 PM
lsturbo*'s Avatar
So does that mean the do not offer the replacement rotors to rebuild my old pump?
Old Oct 3, 2007 | 12:02 PM
Default Re: (lsturbo*)
I don't think so, everyone I know just buys a complete oil pump.
Old Oct 4, 2007 | 07:48 PM
h22a4lude's Avatar
you can use one out of a gsr. but you'll need a gsr timing belt then too.
or that might be the water pump, but im pretty sure its the oil pump
SpoolnG2
Apr 1, 2008 06:15 PM
astralshadow
Jun 12, 2006 06:38 PM
mahatma
May 4, 2006 08:38 PM
Galland
13
Jun 20, 2004 01:23 PM
VWkila
Jan 29, 2003 02:09 PM
