Clocking turbo help?
Old Oct 2, 2007 | 06:14 PM
jgrogan's Avatar
Default Clocking turbo help?
I need a little help here. I was clocking my turbo and on the compressor side it came off after turning it a little bit. There was a orange rubber ring in there. I don't know what it is. I think it is maybe a gasket but it is cut in a like 5 different pieces. Turbo is a precision sc6152e turbo it is a brand new turbo also. Thanks
Old Oct 2, 2007 | 06:19 PM
OLD_HATCH's Avatar
There is a large oring that seals both halves of the compressor housing together. Is this what you found? If so You're going to need to replace it.
Old Oct 3, 2007 | 09:24 AM
jgrogan's Avatar
Yes, that is what I found. If it's a new turbo, why would it have those cuts in the o ring?
Old Oct 3, 2007 | 03:52 PM
platinum00's Avatar
Default Re: Clocking turbo help? (jgrogan)
How did the turbo come apart. Did you take the bolts all the way out?
-platinum
Old Oct 3, 2007 | 06:27 PM
OLD_HATCH's Avatar
Default Re: (jgrogan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgrogan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, that is what I found. If it's a new turbo, why would it have those cuts in the o ring?</TD></TR></TABLE>
You probably clocked the housing and it got pinched somehow. When I was figuring out fitment and needed to constanly clock the housing I took it apart and put some silicone on it so it wouldnt cut/tear.
Old Oct 4, 2007 | 02:30 AM
jgrogan's Avatar
The weird thing is there is a small piece missing. I cant find it anywhere. Im not sure I understand the last post you used just silicone or you used silicone along with the o-ring. Yeah I had the bolts all the way off. I know that is where I messed up and thats what I get. Last question where can I get one and how much.
Old Oct 4, 2007 | 09:07 AM
OLD_HATCH's Avatar
oops sorry about that.
I meant to say that I used silicone spray on the oring so that it would be nice and lubed since I kept turning the housing figuring out fitment. NOT silicone as glue but the spray lube.
Call the manufacturer of the turbo if you cant find that Oring locally.
stknfghtr1
Aug 3, 2011 10:52 PM
stknfghtr1
Aug 3, 2011 06:21 PM
Mr HYDE
Mar 14, 2007 08:39 PM
95whitegizzer
Jun 28, 2006 05:21 PM
Filliam H. Muffman
Oct 3, 2003 02:59 AM
