Boosted Integra - My new build
Not much of a new build. But here was the lowdown.
old setup
New setup
NEW:
UGR cast manifold
3" downpipe
Borg warner turbo
2 slim fans
full radiator/consensor
FULL A/C (cold as ****)
3" inlet 4 1/2" tip Apex N1 Turbo muffler
3" mandrel bent pipe
New intercooler piping
Here's some old pics of the car
old setup
New setup
NEW:
UGR cast manifold
3" downpipe
Borg warner turbo
2 slim fans
At least the wg attaches at a good point on the manifold. A $500 60mm gate that's routed off cyl #1 on the far end is no better.
BTW is that clear PVC line for the WG? Thats all I'd really question, seeing as how PVC + hydrocarbons + heat is a reciepe for disaster...eventually.
IMO, it's better to connect the WG to the turbine housing instead of tapping off the manifold after the TB.
1 suggestion, tie strap all your vacuum lines.
Where do you see PVC? That is vacuum line with a bit of powder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 »</TD></TR><TR><TD CLASS="quote">nice, just like my old setup. i would ditch the fmu and tune it. how does it run? have a clutch?</TD></TR></TABLE>
It will have an AEM soon, bigger injectors and may bump up the boost to 9 or 10lbs not sure...
It runs amazing, now CEL, no vibrations, perfect driving car.
Stock clutch, but when it goes I have a spec stage 3 clutch waiting for it
