overflowing oil catch can...
Old Oct 2, 2007 | 07:32 AM
champLSinteg's Avatar
Default overflowing oil catch can...
I took my car out to the strip on Sunday trying to break 11's. Well first pass I hit 12.5 bogging second pretty bad. Second pass same thing but once I let off the motor was nocking and smoking some. I drove it half way to the pit area and then I decided to shut it off. I pushed it the rest of the way back. I pop the hood and my oil catch can was smoking and had overflowed and spilled oil everywhere and there was smoke coming from the valve cover breather too. I pulled the plugs and #2 was covered in oil. What does this mean? Ringlands went pushing all my oil out and possibly starve the motor spinning a bearing to make it knock? I wont be able to tear it down for another week to see the damage but I want to know what to expect.
Old Oct 2, 2007 | 09:05 AM
street dream gsr's Avatar
* B A N N E D *
Default Re: overflowing oil catch can... (champLSinteg)
well... not sure is will answer the oil on the sparkplug question, but my oil catch can was overflowing because i had an extra quart of oil in there.
Old Oct 2, 2007 | 09:18 AM
Default Re: overflowing oil catch can... (street dream gsr)
mine was just below the top mark on the dip stick before the runs and after it overflowed it was below the bottom one so thats about a whole quart it pushed out.
Old Oct 2, 2007 | 09:20 AM
Topdawgg's Avatar
mine fills up pretty quick at the track..
Old Oct 2, 2007 | 10:06 AM
Redwidow's Avatar
Where do you guys have the catch can hose's plumbed into?
Mine was filling up and over flowing in probably less than 1/4 mile...Got rid of the rear block barbs and used the valve cover approach..I haven't gotten anything in my can yet
Old Oct 2, 2007 | 11:15 AM
CivicVX94's Avatar
Default Re: overflowing oil catch can... (Redwidow)
do you have a drain back? is the can baffled?
Old Oct 2, 2007 | 11:40 AM
Default Re: overflowing oil catch can... (CivicVX94)
I dont have a drain back on the catch can. I rigged up the can myself and put a luffa thing in it as a baffle. The engine is making a lot of noice and knocking but not as loud as a rod knock though.
Old Oct 2, 2007 | 02:44 PM
anyone else have any idea of what the knocking is?
Old Oct 2, 2007 | 02:49 PM
ek_chris's Avatar
when does it knock? what rpm/ does it go away? is it rapid? slow? etc.
Old Oct 2, 2007 | 03:32 PM
Default Re: (ek_chris)
it doesnt go away and it does it all the time and rapid. Its more like chunks of metal rattling in there. Its not hollow sounding like rod knock but that could be it too. I started it after I got home and lots of smoke came out of the breathers.
Old Oct 2, 2007 | 04:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
I used to have that same problem in my car with the endyn catch can. I upgraded to the T1 Race Development catch can it it solved my oil puking problem. http://www.t1raceparts.com/pro...n.htm
Old Oct 2, 2007 | 06:13 PM
Outkast95LS's Avatar
Default Re: (champLSinteg)
Sounds like a spun bearing. Do a leak down test and see if your rings/ringlands are gone.
Old Oct 3, 2007 | 07:04 AM
Default Re: (Outkast95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a spun bearing. Do a leak down test and see if your rings/ringlands are gone. </TD></TR></TABLE>
Sup Jon
Thats what I thought as soon as heard the knock but I looked at my oil pressure and its normal so maybe its something else came loose. I am taking the head and pan off tonight. Sucks cause its a brand new motor.
Serenity Now!
Jan 29, 2007 06:31 AM
SNsLude
Mar 1, 2004 09:30 AM
p1ccoloz
Jul 6, 2003 04:09 PM
Nextelbuddy
May 30, 2003 07:50 AM
integranator
Dec 4, 2002 04:52 PM
