Need a Hondata tuner in the UK (Have searched tuner directory)
Like the title says need someone to tune my B16 using Hondata S300 & innovate wideband.
Am based in the midlands, did find a tuner on here but not repling to e-mails.
Thanks guys.
Thanks guys.
Re: Need a Hondata tuner in the UK (Powelly)
OK
Get onto http://www.hondacrx.co.uk
Look for a user by the name of BGB (Chris) he's not that far from you.
If Chris is unable to help he'll point you to someone that can.
Quite a few people wait for Mase to turn up in the UK, trouble is, if you require tuning work in between his UK visits you could be in for a very long wait.
I'm sure the guys on the above forum will help you.
My advise, research the people to stay away from as well, quite a few tuners that are not quite what they appear to be.
By te way, what's your set-up?
Eddie
Eddie
Thanks man i will do.
Setup wise:
T3/T4 A/R 0.50
FMIC
External wastegate
Wiseco low comp pistons
ACL bearings, Eagle rods, ARP studs
ARP head studs
R/C 550's, AEM fpr
Skunk2 pro series valve springs, titanium retainers
Teg type r oil pump
Cometic MLS head gasket
Hondata S300 & Innovate wideband
Avo coilovers
Prelude 2.2 Vti calipers, 18 groove discs, EBC red stuff pads
Boost bleed valve and some other stuff i can't remember.
Want it tuned @ 8psi to start just to run it all in and get used to it
Setup wise:
T3/T4 A/R 0.50
FMIC
External wastegate
ARP head studs
R/C 550's, AEM fpr
Teg type r oil pump
Avo coilovers
Re: (Powelly)
sod mase. go to TDI South, speak to a guy called sam, tell him nathan with the turbo prelude told you to call. they will sort you out a treat! they sorted mine................. awesomely fast now
LOL! Thanks for the suggestion mate, trouble is i need the S300 socketing in the ECU with a base map put on it so i can drive it to them to be fully tuned hence why im looking for someone local.
Will have a look and see where TDI south are based.
Cheers
Cheers
