just bought an rsx
i want to go with a supercharger kit would like to see some numbers of guys running them on there 02-04 rsx-s are there any others than the jrsc and are my stock injectors ok to use and should i do an intake manifold upgrade any input except negative will be appreciated
The JRSC is good up to about 300whp with alot of supporting mods but that is really pushing it. The best setup that I have found for reliability and fun factor is the JRSC at 7psi with a cai, rh, exhuast, 650cc injectors and Kpro. That setup is good for about 250whp and it is the right amount of boost before the blower starts running out of efficiency.
If you are looking for much more power than that you will want to turbo the car.
Regardless, boost if fun but really addictive. You will never seem to have enough power and that is the reason that I decided to just go turbo.
Good luck with the build.
b18c1ebpsol
Mar 29, 2010 12:00 PM
PickleTeg
Jan 20, 2007 01:16 PM
