Just mounted Inline Pump, is it too low?
Old Oct 9, 2007 | 03:41 PM
96 GSR-T's Avatar
Default Just mounted Inline Pump, is it too low?
Realized it after i ran all the wires and got the lines hooked up and stood behind the car and looked, I can raise it up 1 more inch and move the clamps to the side, does anybody think I will have any problems, Plan on upgrading to a 1k rear spring setup and also raising the rear ride height, anybody think i will have issues?
engine bay shot for ***** n giggles
Old Oct 9, 2007 | 04:12 PM
JDMisGOOD's Avatar
Default Re: Just mounted Inline Pump, is it too low? (96 GSR-T)
I'd raise it up as high as you can.
Old Oct 9, 2007 | 04:39 PM
Brain3208's Avatar
Yea way too low if you ask me, you don't want the lowest point of your car to be something that IF it were to get smacked in a run or whatever to cause you to lean out and destroy such a nice setup...which looks great BTW!
Old Oct 9, 2007 | 05:33 PM
thelate1's Avatar
Default Re: (Brain3208)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brain3208 &raquo;</TD></TR><TR><TD CLASS="quote">Yea way too low if you ask me, you don't want the lowest point of your car to be something that IF it were to get smacked in a run or whatever to cause you to lean out and destroy such a nice setup...which looks great BTW! </TD></TR></TABLE>
ditto^^^
Old Oct 10, 2007 | 07:08 AM
96 GSR-T's Avatar
bump for some relocation suggestions, i dont really want to bolt it to the spare tire well
Old Oct 10, 2007 | 07:21 AM
B18C_EJ8's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">bump for some relocation suggestions, i dont really want to bolt it to the spare tire well</TD></TR></TABLE>
Why not? If you're concerned about strength, through bolt it with some small capscrews or carriage bolts, and fab up a 3x2 inch piece of aluminum or steel plate and layer that on the inside of the tire well... Drill through the plate and the spare tire well at the same time, then put your nuts & lock washers inside on top of the plate...
That'll make it very rigid...
Old Oct 10, 2007 | 07:58 AM
pgpbubble's Avatar
Default Re: (B18C_EJ8)
Mount it on the rear subframe above the sway bar.
Old Oct 10, 2007 | 11:36 AM
B R Fittings's Avatar
Pm'd. I need to know whats going on.
Old Oct 10, 2007 | 12:07 PM
grand champ's Avatar
Nice Jack stands!!!
Ya would definatly get it up higher, would realy suck to get that thing smashed off when you accidently hit a big pothole or somthing.
ohsnapzafingcu
Nov 17, 2013 08:20 PM
civic-r11
Apr 26, 2011 06:26 AM
Sunlight
Oct 24, 2009 06:17 PM
VaporTrail
Jun 25, 2001 12:16 PM
