moroso oil pan users
Old Oct 4, 2007 | 05:22 PM
beaterman's Avatar
Default moroso oil pan users
i just bought a moroso oil pan with the turbo and temp taps. problem is i cant get the plugs that came with it out. any suggestions.
Old Oct 4, 2007 | 05:33 PM
JDMs1eeper's Avatar
Default Re: moroso oil pan users (beaterman)
Might have a sealer on them. I know on the 2 ive owend, they would leak slowly with out a sealer. Maybe they have a dap on them just incase you planned on not using them right away? Good Luck
Old Oct 4, 2007 | 08:06 PM
beaterman's Avatar
Default Re: moroso oil pan users (JDMs1eeper)
anyone got a good suggestion on how to get these plugs out. thanks.
Old Oct 4, 2007 | 11:32 PM
carrnut21's Avatar
free bump for you because i also just bought one and if i face this problem i would also like to know
Old Oct 5, 2007 | 12:10 AM
riceball777's Avatar
get the allen tool and get a big piep for more leverage
Old Oct 5, 2007 | 01:59 AM
bamf3000's Avatar
IF you purchased the street pan, with the magnetic oil drain plug, I recommend getting a new plug. The plug does not seal properly and you will always leak oil. Just a heads up. At least that is what I have, and have heard has happened to quite a few ppl.
Old Oct 5, 2007 | 02:00 PM
Boosted B6teen's Avatar
Default Re: moroso oil pan users (bamf3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamf3000 &raquo;</TD></TR><TR><TD CLASS="quote">IF you purchased the street pan, with the magnetic oil drain plug, I recommend getting a new plug. The plug does not seal properly and you will always leak oil. Just a heads up. At least that is what I have, and have heard has happened to quite a few ppl.</TD></TR></TABLE>
Yep, their oil drain plug is a piece of ****. Just use the proper sized allen socket and a big bar.
Old Oct 6, 2007 | 12:49 PM
beaterman's Avatar
thanks that worked so easily.
Old Oct 6, 2007 | 04:47 PM
kermit97's Avatar
yes the pan is ok but it leaks out have I have same problem.
Old Oct 6, 2007 | 06:01 PM
LSR-Abuser's Avatar
I have had no problems at all with my pan lucky I guess
Old Oct 10, 2007 | 03:46 PM
builtturboeg's Avatar
had mine 3 years never any problems
Old Oct 10, 2007 | 04:06 PM
sfwd996's Avatar
Default Re: (builtturboeg)
anyone problems with them leaking oil? ive tried everything stock gaskets, moroso gasket, hondabond everything, notthing seems to work? might just go back to stock pan
Old Oct 10, 2007 | 04:21 PM
oompalumpa61's Avatar
what's the difference between this pan and the stock pan?
Old Oct 10, 2007 | 08:27 PM
Urban_Indian's Avatar
Default Re: (sfwd996)
SFFWD996 - Use gasket sealer( i use this kind called The Right Stuff) or honda bond and trace the entire pan with it then put on the rubber gasket. Let set for a couple minutes, then put onto the block and only hand tighten the pan , wait ten minutes or so and then tighten in the honda torque spec.
and to take the plugs out of the pan I just used some big vice grips and twisted it off
Old Oct 11, 2007 | 06:42 AM
beaver's Avatar
Default Re: (Urban_Indian)
From my experience using sealer of any kind causes oil leaks. Anytime i have seen pans leaking at the block it was because the gasket was pushed out or some type of "sealer" was used. Clean the surface on the block and the oil pan, get a brand new OEM gasket and torque it to spec. Fixed any leak i have ever had. I have had 2 moroso pans that never leaked on me.
Old Oct 11, 2007 | 07:00 PM
Boostud's Avatar
i plan on getting one of these over the winter. useful info, glad i came across it.
Old Oct 12, 2007 | 04:38 AM
turbo-crx's Avatar
Default Re: moroso oil pan users (Boostud)
the plug comes out very easy with a 10mm or 12mm allen key(cant remember which one) it turns real easy, and as far as the leaking thing goes every time i fixed an oil leak it woulod start leaking somewhere else, i could never get it to stop leaking
Old Oct 12, 2007 | 11:26 AM
Will_H's Avatar
my pan wont stop leaking.. err its pissing me off. Ive done gasket no sealer, leaked. I did gasket with sealer on both sides still leaked now im going to look the pan over for a possible bend in the pan rail or bad weld.
Old Oct 12, 2007 | 08:03 PM
drpoomanchu's Avatar
Crank case pressure???
Old Oct 12, 2007 | 08:23 PM
dartdc97's Avatar
Default Re: (drpoomanchu)
cant stop my moroso pan from leaking either. sealed 3 different times 3 different ways still drips out of the seal only got the pan for the extra .5 qt. not worth it imo but i got it now...
Old Oct 13, 2007 | 12:18 AM
IceySC's Avatar
Default Re: (dartdc97)
im want one of the pan but it seem like alot of youll are have problems from them . were do they manly leak from?
Old Oct 13, 2007 | 07:34 AM
fast93accord's Avatar
Mine came with the plugs not in it. But this is the F22/H23/H22 pan...
The oil temp hole leaked for a month... I put liquid tephlon and tephlon tape and had no luck. I had to use a lot of tephlon tape and really tighten the hell out of it to get a good seal.
As for the drainplug, mine had never leaked once. Your supposed to replace the crush washer everytime you remove the plug.
Old Oct 13, 2007 | 12:28 PM
Will_H's Avatar
it was dripping at idle out of the pan along the tranny side. i could see it puddle up the drip
Old Oct 13, 2007 | 06:36 PM
b00stedbyFastrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban_Indian &raquo;</TD></TR><TR><TD CLASS="quote">SFFWD996 - Use gasket sealer( i use this kind called The Right Stuff) or honda bond and trace the entire pan with it then put on the rubber gasket. Let set for a couple minutes, then put onto the block and only hand tighten the pan , wait ten minutes or so and then tighten in the honda torque spec.
and to take the plugs out of the pan I just used some big vice grips and twisted it off</TD></TR></TABLE>
similar process that I did. no leaks.
Old Oct 14, 2007 | 08:12 PM
Default Re: (b00stedbyFastrax)
yeah i dont know what everyone else's problems are.
my pan leaks a little bit from the drainplug because i used the copper one it came with instead of the poly-euro ones i usually use, but other than that its clean and dry under there
cyn7
Honda Civic (2001 - 2005)
Nov 28, 2011 09:13 PM
z4nd
27
Oct 2, 2010 09:39 PM
tamadrumr88
Dec 24, 2009 04:34 PM
92hatchattack
Mar 3, 2008 09:45 AM
SiB16A
31
Mar 19, 2005 04:33 PM
