common for more lag at less boost?
Old Oct 4, 2007 | 02:24 PM
a1320honda's Avatar
Default common for more lag at less boost?
Ok, so i had my HX35 on my b20 (low comp) set at about 12psi and was making that by 4100 rpm. I just put my GSR in and its set at 7-8psi and its not making 7 till about 5k. But i cant find anything wrong. And the GSR is on break-in so i dont wanna be hammering on it. JUst wondering if it common for a bigger turbo to have more lag at less boost?
Old Oct 4, 2007 | 03:00 PM
david@didrace.com's Avatar
Default Re: common for more lag at less boost? (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">And the GSR is on break-in so i dont wanna be hammering on it.</TD></TR></TABLE>
So you're not at WOT and wondering why it's taking longer to build up boost?
Old Oct 4, 2007 | 04:56 PM
a1320honda's Avatar
Default Re: common for more lag at less boost? (david@didrace.com)
no i get on it, but im not bagin through the gears. im sayin at like 12-13psi in third i would roll into it at about 2000rpm and by 4100 it would be at 12psi. Now with the GSR, doin the same, ill roll into it at about 2000 rpm in third and it takes right about 5000 to see 7psi.
Old Oct 4, 2007 | 05:06 PM
PHDZINE's Avatar
GSR is only 1.8L VS 2.0L. The bigger engine is going to spool the turbo faster.
Old Oct 4, 2007 | 06:01 PM
a1320honda's Avatar
Default Re: common for more lag at less boost? (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">GSR is only 1.8L VS 2.0L. The bigger engine is going to spool the turbo faster.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">GSR is only 1.8L VS 2.0L. The bigger engine is going to spool the turbo faster.</TD></TR></TABLE>ut its 8.1 comp vs 10.1 comp.
And a better tune has something to do with it. On a better tune its alot better.
Old Oct 4, 2007 | 06:08 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">ut its 8.1 comp vs 10.1 comp.
And a better tune has something to do with it. On a better tune its alot better. </TD></TR></TABLE>
Compression doesn't make much difference on lag. He is right. Its your displacement.
Old Oct 4, 2007 | 09:42 PM
quicksilver1689's Avatar
i ♥ snails
head flow has alot to do with it
Dwizzy
Sep 1, 2008 01:22 PM
thegeezerkid
May 28, 2008 07:28 PM
ateggy1
Mar 23, 2008 04:33 PM
HondaTeKnology
13
Feb 8, 2008 05:39 AM
prennro
Aug 6, 2004 09:26 PM
