Q?: Built Head w/GSR Cams or Stock Head w/Cams for Low Boost
Tough decisions.
I'll just get down to the point. I'm debating on two heads which are:
#1) Stock P72 Head (No port, No resurface/milled)
w/Skunk 2 Dual Valve Springs & Ti-Retainers
and Skunk Pro 1 cams
or
#2) Built P72 Head w/the following:
Port & Polish w/3 angle Valve Job
OS ITR Valves
Portflow Dual Valve Spring & Ti-Retainers
& Stock GSR Cams
Set-Up:
B18C 81mm
9:1 CP
Nuekin Ramhorn Mani.
GT35R
Shooting for 420-450 Pump Gas 91 (Boost 11-14psi)
Note: **Must be Daily Driven**
Inputs needed.
or
OS ITR Valves
& Stock GSR Cams
Set-Up:
B18C 81mm
9:1 CP
GT35R
Inputs needed.
Re: Q?: Built Head w/GSR Cams or Stock Head w/Cams for Low Boost (spoonhatchblack)
If I had to choose I would use a stock port head with cams ...
Stock port heads will make well over 600WHP without issue ...
Pro 1's plus a decent compression ratio having motor will net you what your looking for . If I had to guesstimate , i'd say you'll be making around 420-440WHP @ 14lbs
Re: Q?: Built Head w/GSR Cams or Stock Head w/Cams for Low Boost (SPL Dan)
I'd go with number two..
the headwork will be more beneficial than cams at that level.
Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">why not just cams springs n retainers and call it a day? what is the goal of your build?</TD></TR></TABLE>
True can just simply do that. Goal is shooting 4 the upper 430+HP that's why.
