port and polish???
Old Oct 6, 2007 | 02:25 AM
hidiouskinky's Avatar
Default port and polish???
i have to rebuild the bottom end i already have a skunk2 valve train while i have the motor apart would it b in my best interest to port and polish the head....im gonna boost in a little over a yr....the motor is a b18c1 cam gears with stock cams
Old Oct 6, 2007 | 04:30 AM
NJIN BUILDR's Avatar
Default Re: port and polish??? (hidiouskinky)
Depending on your HP goals it is probably not necessary.Stock head is easily good enough up to the 600 ish range.
Old Oct 6, 2007 | 10:02 AM
RC000E's Avatar
Default Re: port and polish??? (NJIN BUILDR)
Not necessary, but a street oriented, forced induction port job can only help you make more power at given boost levels. It's really up to you and how much money you have. If your on somewhat of a budget, pass on it. If you have a good budget and you want the best you can get, then do it. Lastly...be realistic about that budget.
Old Oct 7, 2007 | 04:09 AM
Default Re: port and polish??? (RC000E)
im looking to get 325-350 hp at the wheels....if i get the head job i would b able to get that at lower boost levels...right????and this way i would b able to keep my motor from messing up down the road because of high boost....i mean....thats what im thinking
Old Oct 7, 2007 | 04:31 AM
To some degree the boost level isn't what breaks parts,it's the power your making.A stock ls will make that kind of hp with out porting.A stock gsr head will easily out flow a ported ls head.I wouldn't spend the money porting a gsr head for that kind of power.It just won't make any difference.
Old Oct 7, 2007 | 09:50 AM
ExospeedAMcrx's Avatar
with 300hp, you dont need a port and polish. Concentrate on reconditiining the head with a new valve job and valvetrain. Valvetrain is more important that a port and polish at this hp level. you want to prevent valve float.
Old Oct 7, 2007 | 10:19 AM
lambertincorp's Avatar
Default Re: port and polish??? (ExospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">with 300hp, you dont need a port and polish. Concentrate on reconditiining the head with a new valve job and valvetrain. Valvetrain is more important that a port and polish at this hp level. you want to prevent valve float. </TD></TR></TABLE>
Old Oct 7, 2007 | 11:41 PM
Default Re: port and polish??? (lambertincorp)
since i have a skunk2 pro valve train that is less that 6 months old.....ur saying i should just go ahead and rebuild the block to b boosted and b done with it
Old Oct 7, 2007 | 11:49 PM
another thing to do is check the valvetrain you have if its for the application you plan on using it for.
not all valvesprings/ valvetrain kits are made for UNIVERSAL use. Some are for all motor, some for turbo, etc. The spring rates matter and can determine what is best for the type of use.
If your valvetrain is not matched for a turbo setup, I would suggest getting a different kit that would match for turbo use and the HP level/RPM you plan on taking it up to.
Old Oct 8, 2007 | 04:06 AM
it should b.....when i had the work done....i told my tuner that i was planning on boosting in the near future....but ill ask him and make sure....thanks
Old Oct 8, 2007 | 06:13 AM
morgan@synapse motorsport's Avatar
if it has the stiffer springrate for turbo setups that head can make 500-600+ as it sits. focus on a good solid block for now. save the money on headwork and invest in a good quality turbo setup.
Old Oct 8, 2007 | 06:42 AM
TorganFM.'s Avatar
Default Re: (mike@synapse motorsport)
Stock head + built block, tried and true to 500whp+.
Old Oct 8, 2007 | 09:34 PM
as far as a turbo set-up.....im not going with a kit.....im going to piece one together....i think ill get a better and probably a cheaper **kit** if u will.....im going to try to go with the biggest snail i can fit in the car.....or would that b overkill
Old Oct 8, 2007 | 10:03 PM
doood's Avatar
been there done that
Default Re: (hidiouskinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hidiouskinky &raquo;</TD></TR><TR><TD CLASS="quote">as far as a turbo set-up.....im not going with a kit.....im going to piece one together....i think ill get a better and probably a cheaper **kit** if u will.....im going to try to go with the biggest snail i can fit in the car.....or would that b overkill</TD></TR></TABLE>
get a turbo that meets your hp and powerband goals. also something you can afford.
Old Oct 9, 2007 | 05:26 AM
with enough money im sure you could fit an aircraft carrier under the hood of a civic but that doesnt sound too smart. choose a power goal or track time that you want to acheive. once you have that figured out then build around that. i want it to be fast and powerful will get you headed in pretty much no direction.
Old Oct 9, 2007 | 02:14 PM
Globe1896's Avatar
Aircraft carrier FTW!!
Old Oct 10, 2007 | 12:31 AM
early in the post i said that i was looking for around 350 hp to the wheels.....and if i can get a big enough snail so that i can run lower boost then thats what ill do and if not then ill just have to stick with what i can get
Old Oct 10, 2007 | 11:14 AM
PHDZINE's Avatar
Put the money in a good fuel management. With a good tune your car will last a long time no matter what boost level your at (fuel octane limited).
Old Oct 10, 2007 | 11:13 PM
Default Re: (PHDZINE)
im going with hondata.....it might take me a while to scrimp and save.....but im getting the best
Old Oct 11, 2007 | 10:33 AM
lunatics209's Avatar
i've asked around and i think hondata is good enough.
milanoteggy
Jul 26, 2012 11:54 AM
92db2gs-r
Apr 18, 2011 11:18 PM
efnitup4life
Jan 22, 2011 01:04 PM
hidiouskinky
10
Oct 8, 2007 09:31 PM
v4lu3s
Aug 2, 2003 07:25 AM
