Boosting an H22?
Old Oct 9, 2007 | 08:32 AM
civicb18Tkid's Avatar
Default Boosting an H22?
Ive heard some nasty rumors about boosting H22s and have a buddy who is debating it. Ive heard the blow apart and absolutly hate boost. Are these rumors true? Or are the people ive heard these rumors from just not experienced wit cars enough to know how to properly build one? How much boost can you push on a stock jdm motor with a good tune?
Old Oct 9, 2007 | 09:41 AM
notanotherSC61's Avatar
Default Re: Boosting an H22? (civicb18Tkid)
I can tell you from experience that give it time the ringlands will fail! 8lbs @ 297hp
Old Oct 9, 2007 | 09:45 AM
preludestud11's Avatar
Default Re: Boosting an H22? (notanotherSC61)
give it enough time any motor is going to "fail" the ringlands are the weakeast link on the h22. one care i helped build, has been driving around for 2 years at 267 hp w/ 230 torque on a turbonetics kit, tuned on neptune, with no problems. both my boosted h series outlived my interested in them, i parted out the first one, and i am still driving the car with the same motor in it, and hte second one i sold it to buy a better turbo kit.
Old Oct 9, 2007 | 10:46 AM
so it can be a depandable car with the right builder and tune im guessing...... thanks for the help. anymore info would be awsome
Old Oct 9, 2007 | 11:04 AM
PrecisionH23a's Avatar
Default Re: (civicb18Tkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18Tkid &raquo;</TD></TR><TR><TD CLASS="quote">so it can be a depandable car with the right builder and tune im guessing...... thanks for the help. anymore info would be awsome</TD></TR></TABLE>
Here you go:
https://honda-tech.com/zerosearch
https://honda-tech.com/zerothread/689805
Old Oct 9, 2007 | 11:28 AM
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Here you go:
https://honda-tech.com/zerothread/689805</TD></TR></TABLE>
thanks alot man ill read through that later tonight..... from what i have seen its got real interesting facts
Old Oct 9, 2007 | 01:12 PM
Mikey3000's Avatar
Its true you can't boost H22s. At 1 psi the pistons explode and the crankshaft melts. The only way to fix this problem is to sleeve your pistons.
Old Oct 9, 2007 | 01:51 PM
DfwBB6's Avatar
Default Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">Its true you can't boost H22s. At 1 psi the pistons explode and the crankshaft melts. The only way to fix this problem is to sleeve your pistons.</TD></TR></TABLE>
i heard that rumor too
Old Oct 9, 2007 | 04:54 PM
I know your being sarcastic but do you really need to sleeve it if you want to run like 15psi? couldnt you do some pistons like 10:1 or 9:1 and forge the bottom end and use a block guard? or is sleeveing a must in H22s?
Old Oct 9, 2007 | 05:13 PM
Ok how would this build hold up....
JE pistons (what compression would you recomend?)
Eagle H-beam rods with ARP rod studs
ACL bearings
Golden Eagle block guard
(this is just the block work it would have all other supporting mods)
would this with a proper tune be able to handle around 15 psi? i have basically the same setup in my b18b coupe and its capable of 20psi.
all i really want to know is sleeving needed to run over 10psi or would a block guard work for 15psi?
Old Oct 9, 2007 | 05:32 PM
DfwBB6's Avatar
https://honda-tech.com/zerothread?id=313407
Old Oct 9, 2007 | 07:42 PM
well thats gay but helps out alot. anyone know of what kind of times a del sol with an H22 and t3t4 57tim on 7 psi with some mickey radials would run? like an esimate time?
Old Oct 9, 2007 | 08:22 PM
Runnerdown's Avatar
10.2 @ 145
It could last one day or could last for years. Depends on the brains of who puts it together and tunes it. Same story for pretty much any buildup
Drifter6508
Nov 3, 2009 01:25 PM
Drifter6508
Appearance Build Threads
Nov 2, 2009 03:12 PM
2.2lude88
Jun 22, 2007 05:03 PM
Slomies
Dec 24, 2005 07:05 PM
tranceguy
Oct 5, 2002 10:44 AM
