Ebay turbo kit, d16y8, help
my friend got an ebay turbo kit just installed on his car, it has the external wastegate, hes not gonna run a boost controller, and he wants to run 7psi...
How do we set up the waste gate to run 7psi? the kit came with a black spring, and from what ive been reading thats a 1.1 bar and about 14 psi? does that mean how much is gonna be going into the engine?
Ok, and from my understand i need to have a line going from the turbo, to a T fitting then to the bottom part of the wg, and then a line from the top of the waste gate into the regulator then a line from the regulator to the other end of the fitting
Re: (standbackimapro)
you apply a vacuum line from the side port of the gate leave the top open, is you have a boost controller use the top inline with a v-source i think s 7 psi spring is red
GdmLaz
04-05-2005 03:18 AM
streetfamehatch
03-23-2005 03:59 PM
