td04 turbo
Old Oct 3, 2007 | 03:44 PM
lsteg94's Avatar
Default td04 turbo(wrx turbo)
kc uhey every1 im tryin to find out wut the hell i needa grab up on cuz i heard of sum much different **** and been researching i jus bought a wrx turbo(TDO4) off my boy it has only 1500miles on it thats y i got it plus its small and i only wanna run around 5psi everyday drivin..i have a stock ls with jus the usuall bolt ons but im just posting does any1 no alot about the tdo4 and how it will run on my teg its 94ls thanx alot if u guys can help me out is this turbo also the same as the t25 and that comes from the turbo eclipse and will it bolt up to a t3 or t23 flange for my manifold
Modified by lsteg94 at 5:22 PM 10/3/2007
Old Oct 3, 2007 | 04:31 PM
Schister66's Avatar
Man U FTW
I'm not sure of the flange size but with that turbo you could run it almost wide open....5psi on that little thing is not going to make much power. Its going to spool fast and crap out up top...if it were my setup, i'd get a GM 3bar map and plan to tune on 18psi or so...i'd be shooting for 300whp and know that i'll probably never hit it. Be sure to get a good tune/tuner and you'll be fine
denraweb
Feb 22, 2008 06:20 AM
RubenPrelude
Feb 21, 2008 07:33 AM
LSegHatchy
Mar 12, 2006 11:48 PM
oMek
Feb 17, 2004 07:48 PM
Smokinsax
Oct 13, 2003 10:34 PM
