will this work?
Old Oct 3, 2007 | 01:37 PM
jredhonn's Avatar
Default will this work?
ok.. i have an ej8 w/ d16y8. i am planning to build an engine for my first turbo setup due to the motor in my car has 140k miles, plus i want a better/stronger engine.
plans:
edelbrock turbo kit, vitara pistons, eagle rods, metal headgasket, p&p the head, stock cam, maybe 3 angles valve job.
after i build my engine, i will not put on the turbo kit right away due to money issue....
my question is will my engine running fine/ able to drive before i put the kit on? (9:1 compression ratio instead of 9.6:1 stock)
also, will i able to pass smog due to lower the compression ratio?
thank you
big-cat
16
Mar 7, 2006 07:20 AM
dinku27
Sep 12, 2005 05:28 AM
n8y8
Apr 5, 2005 11:18 AM
95hybridcivic
Nov 14, 2002 02:52 PM
Islander
Aug 24, 2001 02:24 PM
