what turbo is between a t3t4 50tim, and the smallest sc61?
throw me out some ideas and possible dyno's
i haven't seen many honda's with 50 trim dheets or small sc61 sheets
Man U FTW
Re: what turbo is between a t3t4 50tim, and the smallest sc61? (spoolin turbo s)
do you mean the difference in the T3/T04E 50 trim and the smallest Precision SC series OR the smallest version of the SC61. The SC61 is quite a bit larger than the 50 trim...it has a larger exhaust turbine and is capable of 500+whp compared to the T3/T04e 50 trim which is good for around 430whp
Re: what turbo is between a t3t4 50tim, and the smallest sc61? (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">the smallest version of the SC61. The SC61 is quite a bit larger than the 50 trim...it has a larger exhaust turbine and is capable of 500+whp compared to the T3/T04e 50 trim which is good for around 430whp</TD></TR></TABLE>
what is the smallest sc61?
what is the smallest turbo that can make 500-550 with race gas can
i'd rather not go GT serioes im just poor
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Get a T3/T04E 60-trim, .63 a/r exhaust side. Should cost about $550 brand new.
Man U FTW
a 57/60 trim might get you there...i know SLS is pretty close to 500whp on their white hatch w/ a 57 trim and 110octane. Check out the STC Silver Surfer because it might be what you're looking for....also the SC6152sp is a good turbo and would meet your goals; however, is laggier than the other options
Re: what turbo is between a t3t4 50tim, and the smallest sc61? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Get a T3/T04E 60-trim, .63 a/r exhaust side. Should cost about $550 brand new. </TD></TR></TABLE>
this is for a 1.8 20 V VW motor ......57 and 60 trims surge like mad
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">the SC6152sp is a good turbo and would meet your goals; however, is laggier than the other options</TD></TR></TABLE>
that turbo is massive and has a gt35 compressor with t3 stage 3 turbine wheel and can support ~650whp...pretty sure it's the largest of the t3 sc61 available, except for the .82ar turbine housing....probably not a good choice for a vdub.
If you're dead set on Precision, I'd suggest an sc32 which is rated to 49whp and has the bb option or an sc34 which is rated to ~550hp but i don't think it has the bb option. either way, they would spool up much faster than an sc61 and be an overall better choice for a vdub looking for ~500whp
the.hamburglar
08-17-2007 04:21 AM
Tippyman
02-28-2007 07:46 AM
B16CRXT
12-30-2004 01:08 PM
