B20 vtec TURBO build (NEED HELP!!!)
Alright guys I am very excited about this build. New to this forum, but I thought I'd share what I am doing to get a little insight on my build. Just bought a few things to do a massive boost build. I have an EG SI hatch w/ just the b16a block with a Gsr head (Gsr block blew so I replaced it w/ a b16a (don't ask)). Car has been cut in places to lighten up. Sand blasted n a new paint job done by Maaco. (horrible job, so don't recommend it except if you are cheap and broke at the time like me). I want to have a full build by spring so here goes.
Following parts I have at the moment:
HEAD
1. Stock Gsr obd1 head
2. JG Edelbrock intake manifold
3. Obx Fuel Pressure Regulator/ Switching to AEM
BLOCK
1. B20b block w/ Stage 3 sleeves 84mm built by import builders. (Owner worked with Golden Eagle once and started his own shop) so I guess you can say GE sleeved.
2. 8.5 to 1 compression ratio 85mm Wiseco pistons, so I need to bore block to match pistons
3. Micropolished/balanced b20 crank
4. Gsr arp headstuds
5. B20b oil pan tapped for turbo
6. Acl rod/main bearings
Suspension/Brake/Exhaust System:
1. Tokico gas shocks w/ sprint springs (works ok) (suggestions?)
2. Brembo rotors w/ better brake pads
3. 2.5 Apexi exhaust (cracked)
Things I'm want/doing/getting at the moment: SUGGESTIONS please!!!
1. Getting full race port n polish (getting done by a reputable person)
2. 3 or 5 angle valve job
3. Full Magnaflow exhaust only 2.5 but getting 3" something?
4. New polyurethane bushings
5. Front n Rear Camber Kit
6. Want to put block girdle in for extra protection
7. Eagle rods?
8. Complete valve train, but don't know what to get
9. Turbo? Turbo kit? Definitely a ram horn design exhaust manifold, but what brand? Full Race?
10. Aem ems
11. Msd
12. Etc..................
I need a lot of suggestions and set ups that worked. I am aiming a 400 to 600 plus whp. Let me know what you experts know. I still have a few g's left to spend on the build including labor and I don't like to go cheap, but I do like cheap stuff that performs very very well. Thanks and hope to get a lot of suggestions.
HEAD
BLOCK
7. Eagle rods?
10. Aem ems
11. Msd
Re: B20 vtec TURBO build (VeeL_B20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeplsm2 »</TD></TR><TR><TD CLASS="quote">goodluck</TD></TR></TABLE>
Re: (t04b60-1)
This is costing me a fortune at the moment, but it is all paid and worth it in the end. Let me know what you guys have done to your motor to run those high 500 horses so that maybe I can copy a little of it.
Re: (VeeL_B20)
you planning to run a GT35R,GT37 or GT40? cuz I have almost the same setup but JE pistons and eagel rods and no head work. also lookin for the 400whp range aswell but I wanna spool at 4000/4500rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeL_B20 »</TD></TR><TR><TD CLASS="quote">BLOCK
1. B20b block w/ Stage 3 sleeves 84mm built by import builders. (Owner worked with Golden Eagle once and started his own shop) so I guess you can say GE sleeved.</TD></TR></TABLE> sounds like a good build and good luck with the build but just to clear things up jeff never worked here he was a customer but never worked here
Re: (Mr.Blondie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Blondie »</TD></TR><TR><TD CLASS="quote">you planning to run a GT35R,GT37 or GT40? also lookin for the 400whp range as well but I wanna spool at 4000/4500rpm. </TD></TR></TABLE>
To think of it, I've never thought about a turbo. I guess in my case I want to fully build the motor and then look for a turbo kit, but which one? I might just custom my own. I like the gt35r and have heard a few good things with this turbo. I still have a little more research on which turbo to go with but at them moment just trying to finish the build. I will update and post pictures.
Re: B20 vtec TURBO build (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote"> sounds like a good build and good luck with the build but just to clear things up jeff never worked here he was a customer but never worked here</TD></TR></TABLE>
Don't really know Jeff, but that's what I heard. Anyways thanks for the comment. Very reassuring about the build.
definately have a good start.
start off at 84mm, it leaves more room for error in the future. wiseco makes a good piston, but you can run the compression anywhere between 9 and 10:1.
i personally like oem bearings, but the acls will work fine.
what are the spring rates on those sprints? i think you'll need something at least a few hundred lbs/inch to keep a lightened 400+hp car down.
eagle rods will be fine, and you dont need a block girdle.
what kind of rpm limit are you looking toward? itr/skunk/blox cams seem to all have good results, with i think the sks2's yeilding large gains if timed properly. dont spend the money on a full port job, not necessary for your goals. a 3 angle should be done to help clean up the seats.
the magnaflow mufflers are awesome imo, but you will definately need 3". i run a kteller 3" piping kit, no cat with a magnaflow 3" straight through muffler. exhaust is awesome and cost less than 300 bucks because i did all the welding myself.
yea im building the same thing but im going alil bit left with my build the bottom end will be a bit of a true frankenstein setup its gonna be amix of b,h,and k. im doin my homework so it should come out very intresting also my head of choice is a gsr but with chambers to mimic the ones in the si head just so i can get the best of both worlds.
Re: B20 vtec TURBO build (ek9phantom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9phantom »</TD></TR><TR><TD CLASS="quote">yea im building the same thing but im going alil bit left with my build the bottom end will be a bit of a true frankenstein setup its gonna be amix of b,h,and k. </TD></TR></TABLE>
How do you do that? Never heard of mixing it like that? Interesting. Is there a forum of some sort to explain more of this? Let me know. Thanks.
Re: B20 vtec TURBO build (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote"> i run a kteller 3" piping kit, no cat with a magnaflow 3" straight through muffler. exhaust is awesome and cost less than 300 bucks because i did all the welding myself.</TD></TR></TABLE>
Hey thanks for this info. Never would of even found out about it. And yeah my dad welds too so I could just give it to him to weld it at his work place. Just wondering on the performance? What is is compared to as in name brand? Same horse gain? This might be a good route to go if it gives good gains. Thanks.
punkassazn
12-10-2004 03:25 PM
