Help the NooBie! How do i read the names of turbos & understand what it means?
take this for example.
T3/T04e 57trim .63ar
what does each thing mean? can someone break it down for me?
Re: Help the NooBie! How do i read the names of turbos & understand what it means? (unLucky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unLucky »</TD></TR><TR><TD CLASS="quote">take this for example.
what does each thing mean? can someone break it down for me?</TD></TR></TABLE>
http://www.turbobygarrett.com/....html
I wish I could, but I'm as clueless as you. I'll keep posted for my education also.
Good luck
Good luck
Re: Help the NooBie! How do i read the names of turbos & understand what it means? (rdeezy78)
this one even has pictures and mathematical formulas http://www.turbobygarrett.com/....html
in lames terms
T3 designates the exhaust side is a t3
T04 desogmates the compressor side is a t4
E designates the housing on the compressor side is an E housing, some are t3/t04b, the b has a smaller compressor cover...
ar ratio and trim are best if you read the artilce's posted above...
anyways all this crap affects flow/spoolup/where peak power is made/etc... by understanding the basics you can get a "general" idea of what a certain turbo will do on a certain application. CR ratio engine size cams all play a roll too so i use the term "general" loosly here.
in lames terms
JDM.Accord
03-28-2006 01:39 PM
racinskittle
06-02-2003 08:42 PM
