oil in intercooler
Old Oct 6, 2007 | 09:34 AM
boostedh22lude1's Avatar
Default oil in intercooler
i pulled off my intercooler to find oil all inside is it the turbo seals or could it be somthingelse any help appr. thanks
Old Oct 6, 2007 | 10:23 AM
Default Re: oil in intercooler (boostedh22lude1)
bump
Old Oct 6, 2007 | 11:01 AM
sohczcturbo's Avatar
sounds like seal in turbo to me. What kinda turbo, is it an actual name brand or "ebay", and are you running a oil restrictor?
Old Oct 6, 2007 | 11:04 AM
Default Re: oil in intercooler (sohczcturbo)
what is a oil restrictor?
Old Oct 6, 2007 | 11:19 AM
it restricts oil to the turbo. Honda's are known for blowing ebay turbo seals because of their high oil pressure. A oil restrictor limits the psi to the turbo to a point where it's getting enough oil to safely lube and cool the bearing in the turbo, but not enough to damage and bleed by the seals. I did this to my ebay turbo. I don't think they use good seals in them. I've seen people with name brand turbo's not have to run an oil restrictor. So I take it you are on an ebay turbo?
Old Oct 6, 2007 | 11:21 AM
Schister66's Avatar
Man U FTW
seals in the turbo are gone...time for a rebuild.
What size feed line are you running? What does your drain look like? How many miles on the turbo?
Old Oct 6, 2007 | 11:23 AM
BlueSi2k's Avatar
Default Re: (Schister66)
happened to me a couple years ago with a brand new garrett turbo. compressor seal was bad right outta the box. I had oil shooting out of the bov.
Old Oct 6, 2007 | 11:27 AM
Default Re: (BlueSi2k)
yep, my last setup did it too. Oil restrictors are like $12 or so last time I checked. Sometimes you can put one on and it won't leak anymore oil if it didn't damage the seals it just bled past them. Other times you gotta fess up and get a turbo rebuilt.
Old Oct 6, 2007 | 12:18 PM
Default Re: (sohczcturbo)
were can i get an oil restrictor?
Old Oct 6, 2007 | 12:24 PM
http://cgi.ebay.com/ebaymotors...wItem
lol ironic its on ebay.
Old Oct 6, 2007 | 12:25 PM
TheShodan's Avatar
Moderator
Be careful that you know what size the restrictor is IF you even need it. You can easily make a bad situation worse.
Gunner142
Nov 12, 2009 04:38 AM
SurferDude905
Apr 29, 2009 08:47 AM
hold your breath
Feb 14, 2007 10:01 AM
mysss2k
Jan 5, 2005 12:33 PM
SynTeg
Jul 28, 2004 01:27 AM
