some suggestions please?????
Old Oct 3, 2007 | 09:08 PM
nolicense526's Avatar
Default some suggestions please?????
ok, im looking for a winter project. right now i have a drag turbo set up on a stock b16a motor. i want to be able to run about 15 - 18psi without having to worry about anything. i dont have big bucks so this would have to be a budget build. I know i have many options and i want to do this the easiest way. I would like to keep stock head for this winter can do headwork next offseason...
sooo, do i keep my b16 and build that or get an ls motor cheap and use that bottom end with my head? after i decide what block to use, what would you guys suggest me using internally to run about 350hp? im assuming that would be around 15psi to get those numbers. i know arp headbolts are the first thing to swap....but what pistons and rods? and would you suggest boring and sleeving? please help me out
The turbo set up i have isnt that bad so i can probably stay with this for awhile. its a 57 trim .63a/r turbo, log style manifold, 550cc injectors, stock intake manifold, stock fuel rail, fmic, external 38mm tial, blitz bov, obd1...what should i change? thanks for the help!
Old Oct 4, 2007 | 01:10 PM
Default Re: some suggestions please????? (nolicense526)
bump....any help?
Old Oct 4, 2007 | 01:30 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
I would just use the b16 and save some money for any problems you run into because your making it clear you dont have alot of cash. and some bigger injectors too
CRXherbie91
Welding / Fabrication
Nov 15, 2012 01:24 AM
ef71510
Aug 4, 2011 08:13 AM
b18 hatch mike
May 20, 2010 05:21 PM
laziebun
Mar 8, 2009 12:47 AM
lsvtechatch92
Jul 29, 2007 03:08 AM
