should i or not?
Old Oct 4, 2007 | 12:28 AM
spgcuantik's Avatar
Default should i or not?
well my friend is giving me a deal on a 2000 type r head comes with dizzy no intake mani and head jus got resurfaced, he wants 600. i have a mild built GSR block 9:1 je pistons,eagle rods,acls bearings,block guard, 82mm bore, micropolished crank. get the type r head or jus run a full GSR. im going to keep the head stock my goals are around 275-325 HP running about 8lbs. another question is which would be more benficial with a PnP later on when i go all out? or does it depend on the PnP. are the flow characteristics the same or does it matter where i send it to? example portflow VS JUN oh ya will this lower my compression with these pistons or is the head gasket i use?
Old Oct 4, 2007 | 01:21 AM
blinx9900's Avatar
Default Re: should i or not? (spgcuantik)
the type R head will lower your compression compared to a gsr head, about .2 i believe... i have a type R head i like it, im sure everybody has an opinion, id get the type r head, keep it, build the gsr head on the side, then put it on when your ready and just sell the type R head again...
dayaftertomorrow
Feb 13, 2006 02:03 AM
Cboy1-EG6
13
Jun 6, 2005 01:20 PM
Sik Wit It Hatch
Nov 11, 2004 08:06 PM
moreno
19
Oct 30, 2003 07:59 AM
itr1236
Jul 14, 2001 09:32 AM
