has any1 had a meutek turbo mainfold
Re: has any1 had a meutek turbo mainfold (jimmyizcool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmyizcool »</TD></TR><TR><TD CLASS="quote">i have a meutek manifold and i never heard anything about it any1 out there even tested one </TD></TR></TABLE>
the oil dip stick will not go in right because its too thick. ill try to get pics up.
Re: (jimmyizcool)
you have to get a wastgate elbow to fit a tial 38mm because the opening is close to the motor too. but it spools fast, and i doubt it is going to break anytime soon.
Re: has any1 had a meutek turbo mainfold (anton_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anton_ »</TD></TR><TR><TD CLASS="quote">i have one, it is realy important that you use a 5 bolt turbine.
iam very pleased with it</TD></TR></TABLE>
why would one have to use a 5 bolt?
Re: (Hotori Hanso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso »</TD></TR><TR><TD CLASS="quote">you have to get a wastgate elbow to fit a tial 38mm because the opening is close to the motor too. but it spools fast, and i doubt it is going to break anytime soon. </TD></TR></TABLE>
What kind of turbo did u run.Bkuzz Im running a sc61 60 trim and im worried that i might get to much turbo lag.
Re: (jimmyizcool)
I'm about to use one. Does anybody know the size of bolts for the wastegate and the manifold to turbo size.
I know the rev hard bolt size doesn't fit.
Anybody?
Thanks in advance
Anybody?
Thanks in advance
Re: (inthad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inthad »</TD></TR><TR><TD CLASS="quote">I'm about to use one. Does anybody know the size of bolts for the wastegate and the manifold to turbo size.
Anybody?
Thanks in advance</TD></TR></TABLE>
just take the manifold to homedepot or lowes and search their bolts for ones that fit. Thats what i did for my set up atleast w/no problems
Anybody?
Re: (inthad)
Anybody?
m8x20 for a tial wastgate. 3/8 for the turbo, length depends on what turbo you use.
Anybody?
Re: has any1 had a meutek turbo mainfold (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg »</TD></TR><TR><TD CLASS="quote">with a 4 bolt, the turbo will not clear the block (even with shaving).</TD></TR></TABLE>
Not true, mine was with a standard garrett 57 trim t3/t4oe 4 bolt
Re: (inthad)
From my reading it seems that LS blocks can have the wastegate straight off the manifold and any vtec heads need an elbow.
Make sure to go with a 5-bolt turbo housing!!
Re: (97CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR »</TD></TR><TR><TD CLASS="quote">From my reading it seems that LS blocks can have the wastegate straight off the manifold and any vtec heads need an elbow.
Make sure to go with a 5-bolt turbo housing!! </TD></TR></TABLE>
Yes LS motor no need for the elbow, but with a b16 head i had notch/sandd own the head /valvecover to get it to fit well, and the hood closed no probelm for me (99 hatch)
*****and you dont need a 5 bolt housing, standard garrett 4 bolt housing fit as well*****
Re: has any1 had a meutek turbo mainfold (akira712)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akira712 »</TD></TR><TR><TD CLASS="quote">
i think he means if you're keeping a/c it won't clear because the turbo sits the other way..compressor will hit the block
