86mm boost?
Old Oct 4, 2007 | 10:27 PM
primerEG's Avatar
Default 86mm boost?
my block was sleeved and bored to 86mm for allmotor, but low on funds. can i go boost on that block or is the wall to thin. my block was sleeved by darton.
Old Oct 4, 2007 | 10:39 PM
Garcia-Racing's Avatar
Too thin IMO.
Old Oct 4, 2007 | 11:24 PM
s2kdre's Avatar
Default Re: (Garcia-Racing)
my friend was using 86mm GE sleeves with boost and no problems.
Old Oct 4, 2007 | 11:37 PM
primerEG's Avatar
Default Re: (s2kdre)
how much did he boost cause i want to boost alot.
Old Oct 5, 2007 | 01:02 AM
SD_Lurker's Avatar
HT White Ops
Default Re: (primerEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primerEG &raquo;</TD></TR><TR><TD CLASS="quote">how much did he boost cause i want to boost alot.</TD></TR></TABLE>
If your low on funds then you really don't have much of a choice, do you? I would say screw it and give it a shot. Its not recommended by lots of people but then again there are people that have done it. Then again you could just sell that block to an all motor guy and take whatever money you get from that and put it towards your new bottom end. Its either sell it to an all motor guy or press your luck and give it a shot. I say go for it if your really that pressed on dough!
Old Oct 5, 2007 | 01:04 AM
D@nnY's Avatar
its going to blow headgaskets....
Old Oct 5, 2007 | 06:01 AM
Chris Tune's Avatar
Default Re: 86mm boost? (primerEG)
your too low on funds for allmotor and you want a lot of boost? lol thats an oxymoron right there.
Old Oct 5, 2007 | 06:32 AM
Brain3208's Avatar
I'd say go for it and run what you have if you don't have the funds for another engine, it all in the tune anyhow. but that is a bit of a large bore. how high is the compression? just start saving up for another engine asap cause eventually its gonna go.
Old Oct 5, 2007 | 08:28 AM
PHDZINE's Avatar
Default Re: (Brain3208)
Keep your boost to a minumum...18-20PSI MAX!!!
Old Oct 5, 2007 | 08:29 AM
Schister66's Avatar
Man U FTW
i have an idea....dont go all out and it'll work. Its not that it cant hold any power, but if you try to throw 600-700whp at it, then it might break...stay under the 450whp mark IMO and you'll be just fine
Old Oct 5, 2007 | 09:07 AM
primerEG's Avatar
Default Re: (Schister66)
i'll give it a shot. the thing is that i was running allmotor then and had that block ready to go all out, but in the process, i decided to try boost out. right now i have a gsr stock with turbo and it has 325whp. im loving it. i just wanted some suggestions. thanks.
Old Nov 22, 2007 | 08:15 AM
Cole D's Avatar
any updates
Old Nov 22, 2007 | 03:13 PM
187Chor's Avatar
if ur low on funds dont start to boost..
the expenses pile on quickly, and u will be on thin ice with 86mm and high boost.. IMO
Old Dec 9, 2007 | 09:54 AM
primerEG's Avatar
where can i get some 86mm pistons and rings for a good deal
Old Dec 9, 2007 | 10:37 AM
96 GSR-T's Avatar
Headgaskets are going to own you.
Old Dec 9, 2007 | 10:41 AM
quicksilver1689's Avatar
i ♥ snails
there isnt going to much surface area between adjacent cylinders for the headgasket to seal,like stated earlier it could become a problem
Old Dec 9, 2007 | 11:00 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
how can you afford all the parts it takes to boost, if you can't afford less parts for NA... doesn't make sense
Old Dec 9, 2007 | 12:17 PM
m R g S r's Avatar
not enough area between the cylinders to keep the HG's sealed......
Old Dec 9, 2007 | 05:45 PM
SteamedRice's Avatar
Default Re: 86mm boost? (m R g S r)
may i ask a question here instead of starting a new thread for a quick Q?
i'm deciding on displacement (bore) for my complete teardown and rebuild b18c1. 9:1 compression and stock stroke... the HP aim is 550HP, my guess is that would be 24-32psi tops?? not sure. i was thinking of 84mm bore on darton MID sleeves is this safe?
Old Dec 9, 2007 | 05:50 PM
Jared's Avatar
for reliability's sake either resleeve it or trade it to an all motor guy for a smaller bore or unsleeved.
Old Apr 25, 2008 | 08:50 AM
ghostofnyc's Avatar
i know of a few 86mm bores running strong 800+whp
Old Apr 25, 2008 | 09:09 AM
86mmboosted_da's Avatar
86mm on boost here. nothing wrong, everything fine. Just stay under 450 whp and max of 20lbs of boost. But boy o boy do you get some good tq out of that bore. Wiseco can make the pistons for you, go for std 9.0:1 comp and you'll be fine.
Old Apr 25, 2008 | 09:51 AM
96 GSR-T's Avatar
Must be a Florida thing, I know I would be scared to death to boost 86mm.
ILS_Thatstight
Sep 12, 2006 06:42 PM
PIFFSTAR
Feb 15, 2005 06:49 AM
CivicGSR225
Oct 15, 2004 03:17 AM
CrVtec122
Jun 8, 2004 05:31 PM
The_Robster
Oct 30, 2002 02:41 PM
