b18 crower stroker kit Experience
Old Oct 3, 2007 | 05:32 PM
ral24_hct's Avatar
Default b18 crower stroker kit Experience
Hello need information if the crower stroker kit i good or not for turbo aplication 95mm strock 84 bore thnx
Old Oct 3, 2007 | 05:47 PM
dart2.2's Avatar
Default Re: b18 crower stroker kit Experience (ral24_hct)
you need a deckplate or a tall deck dart block for that stroke. im about to finish up my turbo stroker setup.i used the dart setup because it was actually cheaper than deck plating and sleeving a stock block and alot stronger for the money.
Old Oct 3, 2007 | 08:01 PM
doood's Avatar
been there done that
Default Re: b18 crower stroker kit Experience (dart2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dart2.2 &raquo;</TD></TR><TR><TD CLASS="quote">you need a deckplate or a tall deck dart block for that stroke..</TD></TR></TABLE>
or shorter rods. which im sure come with the bc kit.
Old Aug 22, 2009 | 10:16 AM
S2Integra's Avatar
What is Bobismoi talking about? If it is a 2.0L why would it be a B18C5? It would be a B20 something, and the C5 is the North American version of the ITR not Japanese.
Old Aug 22, 2009 | 11:59 AM
madblkscientist's Avatar
they made 2.0 version of the type r in japan ,hard to come by
Old Aug 22, 2009 | 12:03 PM
Muckman's Avatar
Moderator in Chief
myth
Old Aug 22, 2009 | 12:21 PM
Turbo-LS's Avatar
stroker kit is a complete waste of time IMO, not to mention the cranks are junk and no where near as strong as a stock crank.
bigger displacement isnt needed with a honda engine as they are very effecient and will make more power then your probably looking for with all the proper equipment.
if you want slap in a 89mm LS crank into the vtec block with ls rods
im running LS rods and crank with gsr pistons in my gsr block and it makes crazy power on pump gas, havent even bothered with race gas its fast enough for me
Old Aug 24, 2009 | 09:38 PM
hpmx18's Avatar
deck plate is not needed, on my setup i had je made me pistons that fit on my stock eagle ls rods,a nd its worked out fine for me, give JE a call they hook u up
kennethNA
Mar 23, 2009 11:59 PM
migs
Aug 13, 2004 02:56 PM
coldwhiteass
May 1, 2004 01:27 PM
stale1 '01 itr 616
16
Aug 17, 2003 08:20 PM
HX_Guy
Dec 6, 2001 03:01 PM
