aftermarket timing belts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Cons: Cost
Otherwise, if you can afford it, it is always good to run one with high lift cams. </TD></TR></TABLE>
but all good things come at a price
So unless you rev high, there are no benefits to running an aftermarket timing belt? Would they be less likely to jump? The time to replace my stocker is coming up, so I'm just seeing what my options are...
Thanks
Thanks
Might as well do it - they are stiffer supposedly and stronger so less likely to stretch at higher rpms. So that makes them less likely to wear down quicker than stock and less likely to jump if that answers your question. I know the toda one proposes its 200% more stronger over OEM
