Will a turbo, Fluidyne radiator, and FAL fans fit?
Old Oct 20, 2003 | 01:30 PM
ThePro's Avatar
Default Will a turbo, Fluidyne radiator, and FAL fans fit?
Just like the topis says, I want to turbo my teg and I have a Fluidyne radiator and some FAL fans installed. The space is decreased with the radiator and increased with the fans. Will the whole thing fit? Anyone seen or have this setup?
Old Oct 20, 2003 | 01:34 PM
SuzukaBlueAP2's Avatar
Default Re: Will a turbo, Fluidyne radiator, and FAL fans fit? (ThePro)
I have heard it will fit, tightly. I have the fluidyne rad., and had a turbo on my LS once, it was definitely a tight squeeze. I don't think I could've fit FAL fans. I ended up mounting my stock fan on the front of the rad. But i did have a dent rad support, so that may have had something to do with it.
Old Oct 21, 2003 | 06:16 PM
Muckman's Avatar
Moderator in Chief
Are you talking about the full width rad or the half "civic style" radiator?
Old Oct 22, 2003 | 02:34 PM
ThePro's Avatar
Full width. If you know of a manufacturer that makes a good full width (but not as thick) radiator, lemmi know.
Old Oct 22, 2003 | 03:32 PM
NuclearB18B's Avatar
Default Re: (ThePro)
i have an ls with the inline pro, sc61, and the fluidyne. there wasn't enough room for the stock ac condenser fan. so i'm using just the ac condenser fan on the passenger side of the radiator. i couldn't find a good way to mount on the other side of the radiator, so i'm just using the one. it seems to be working fine, no overheating problems at all. but i don't know how is will affect the ac condenser. anyone know?
Old Oct 22, 2003 | 04:22 PM
PM-Performance's Avatar
Default Re: (ha illuminato un)
run the fluidyne and just make the fans pushers,saves a **** load of space
Old Oct 22, 2003 | 04:35 PM
P1mpSlap's Avatar
you aren't running a big enough turbo if it does.
Old Oct 22, 2003 | 06:22 PM
Muckman's Avatar
Moderator in Chief
Default Re:
Pros and cons of running full length Integra rad with 1 fan vs half length civic style rad with 1 fan. Is dual core really just as effective as single core, double width?
Old Oct 23, 2003 | 01:12 PM
Default Re: Re: (Muckman)
if you get an aftermarket dual core single length rad, you will be more than fine
everyeons doing it , it cant be bad
Old Oct 23, 2003 | 04:13 PM
ThePro's Avatar
Is there enough room in front of the radiator to make the FAL's pushers with the A/C still there?
Old Oct 25, 2003 | 07:19 PM
R.S.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro &raquo;</TD></TR><TR><TD CLASS="quote">Is there enough room in front of the radiator to make the FAL's pushers with the A/C still there?</TD></TR></TABLE>
bump
i would like to know too
Old Oct 25, 2003 | 07:59 PM
mskibbz-T's Avatar
C'mon now, its not hot in Lacey, pull that AC out and get some space and 35+ lbs
4piston
Jan 27, 2005 07:11 PM
billyhoe
Nov 2, 2004 10:57 PM
wdskuk
Jan 6, 2004 11:39 AM
Ri5e
Jun 19, 2002 07:47 PM
