Oil Drain Plug Gasket
Old Oct 21, 2003 | 02:33 PM
zomart's Avatar
Default Oil Drain Plug Gasket
hey,
i had to replace my oil plug and was wondering what to do for a gasket. i always thought they were just metal washers (14 mm for my gsr), but the plug i bought came with a 14 mm plastic thing that kind of looks like a washer, but it has like a wavy cut in the middle circle. i'm not sure if this thing's supposed to be the gasket or not... and also, when i have to replace it, what should i replace it with? just a 14 mm metal washer?
Old Oct 21, 2003 | 02:35 PM
B2FiNiTY's Avatar
Default Re: Oil Drain Plug Gasket (zomart)
The OEM drain plug utilizes a washer. If you are afraid it won't seal well then you can use liquid thread or teflon tape on the threads to seal it better.
P1mpSlap's Avatar
replace it with the correct size crush washer. It's only there to prevent over torquing on the drain plug.
Old Oct 21, 2003 | 02:40 PM
zomart's Avatar
Default Re: (P1mpSlap)
is a crush washer different then just a plain old washer?
Old Oct 21, 2003 | 02:54 PM
ragejed's Avatar
Default Re: (zomart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart &raquo;</TD></TR><TR><TD CLASS="quote">is a crush washer different then just a plain old washer?</TD></TR></TABLE>
yes, a crush washers crushes...they are softer then a normal washer.
Old Oct 21, 2003 | 02:55 PM
P1mpSlap's Avatar
Default Re: (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">
yes, a crush washers crushers...they are softer then a normal washer. </TD></TR></TABLE>
yeah, they are normally made out of soft aluminum rather that stainless steel.
Old Oct 21, 2003 | 02:58 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, they are normally made out of soft aluminum rather that stainless steel.</TD></TR></TABLE>
or copper
Old Oct 21, 2003 | 03:10 PM
zomart's Avatar
beautiful... does that mean a trip to the dealer?
Old Oct 21, 2003 | 03:12 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart &raquo;</TD></TR><TR><TD CLASS="quote">beautiful... does that mean a trip to the dealer?</TD></TR></TABLE>
yep... normally they are free, if not i think they are like 18 cents.... whatever the cost is, its not gonna make you pay your rent late
Cactus
Jan 20, 2009 06:17 PM
Lilredwagon
Oct 19, 2006 03:34 AM
WhitEdRift
Feb 13, 2004 10:44 PM
