Where is the Service Connector at?
Old Oct 20, 2003 | 08:30 AM
integranator's Avatar
Default Where is the Service Connector at?
I wanted to reduce timing in my 98 integra-- do you have to jump the service connector?? If so, where is it, and how do I do it?
Old Oct 20, 2003 | 08:33 AM
fivespeedintegra's Avatar
Default Re: Where is the Service Connector at? (integranator)
i don't think you need to jump the connector....you just need a timing gun.
connector is on the passenger side, down by the rear of the head unit.
hope that helps n!
Old Oct 20, 2003 | 08:48 AM
Padawan's Avatar
Darth ModerVader
Actually, the connector he's referring to (the one that must be jumped when adjusting timing) is the two-pronged connector located closer to the ECU.
Old Oct 20, 2003 | 08:54 AM
Default Re: Where is the Service Connector at? (Padawan)
Which connector are you referring to??
Old Oct 20, 2003 | 08:59 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">Which connector are you referring to??</TD></TR></TABLE>
As I said, it is a two-pin connector located under that dash somewhat near the ECU. I haven't been under there in a while, but I believe it is brownish with a green rubber cover over it.
Old Oct 20, 2003 | 09:02 AM
timmy8151's Avatar
Isn't it located under the glovebox on the passenger side?
Old Oct 20, 2003 | 09:04 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Where is the Service Connector at? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it located under the glovebox on the passenger side?</TD></TR></TABLE>
correct.
Old Oct 23, 2003 | 09:32 PM
guys, after i've done the timing adjustment, do I need to keep the jumper in the connector?? or can I take it out???
Old Oct 23, 2003 | 09:59 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">guys, after i've done the timing adjustment, do I need to keep the jumper in the connector?? or can I take it out???</TD></TR></TABLE>
Take it out. With the jumper in place, the CEL should be illuminated.
lakerschamp2000
Aug 15, 2005 06:49 PM
the.hamburglar
Oct 14, 2004 11:37 AM
integranator
Aug 30, 2003 08:23 AM
Daniel
Aug 22, 2003 07:05 PM
JdmIntegra98
Jul 2, 2003 10:10 PM
