car keeps popping 100 AMP fuses!
Old Oct 22, 2003 | 05:11 PM
EK MONEY's Avatar
Default car keeps popping 100 AMP fuses!
It is a 1994 LS, a buddys car of mine. His other friend did a swap on it(LS to LS) and it worked good for 2 days and now he went around a courner and it popped. I replaced it and it keeps popping. I checked all the grounds, all the power wires, what could this be? I was thinking alternator.. any info is good info. OH by the way, its the main battery fuse.
Old Oct 22, 2003 | 05:32 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: car keeps popping 100 AMP fuses! (Peagreenhatch)
Recheck grounds, check for shorts.
If you can't find it bust out a volt/ohm meter.
Old Oct 22, 2003 | 06:47 PM
t's Avatar
t
When does it pop?
If it pops right away-Dead short, look at the main cables that connect to the fuse box and/or battery
spooncivicsi
13
Jan 31, 2022 05:13 AM
BrandonPell
Aug 30, 2018 11:03 AM
Juju2010
Apr 14, 2015 11:15 AM
mjrage
Jun 25, 2004 08:09 PM
EK MONEY
Oct 22, 2003 05:17 PM
