Engine Overheating... and... heater stops working?
Old Oct 20, 2003 | 06:47 AM
BigC-ivic's Avatar
Default Engine Overheating... and... heater stops working?
Engine Overheating... and... heater stops working.
So the obvious prob would be a lack of coolant... nope... I have tons of it
The overflow is almost full
and... there is coolant on the top of my rad... like its busting out of there
Any ideas what is wrong, could it be the thermostat?
Old Oct 20, 2003 | 08:00 AM
BigC-ivic's Avatar
Default Re: Engine Overheating... and... heater stops working? (BigC-ivic)
it appears as though my fan is not coming on... I may have found the prob
Old Oct 20, 2003 | 08:22 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">So the obvious prob would be a lack of coolant... nope... I have tons of it
The overflow is almost full...</TD></TR></TABLE>It's possible for the overflow bottle to be full while the radiator isn't. Did you open the cap & look?
Fan not coming on... Jumper the wires for your fan switch to see if that makes the fans run. If they run, bad fan switch. If they don't, look for fuses, relays, wiring, or a bad motor.
Old Oct 20, 2003 | 08:36 AM
Acura_I-RS's Avatar
Default Re: Engine Overheating... and... heater stops working? (JimBlake)
replace your thermostat too!
Old Oct 20, 2003 | 08:43 AM
lewd43's Avatar
u might also want to check to see if ur radiator has a crack along the top near the neck, my radiator did that and sprayed coolant all over the engine bay, but it never overheated. just a possibility
Lred1993civiccx
22
Jun 29, 2019 05:36 PM
redbull99
Aug 27, 2015 10:19 AM
hotcivicsi
11
Apr 9, 2009 06:19 PM
Twistedframe
May 24, 2007 08:26 AM
Nickg116
Mar 31, 2007 06:20 AM
