anyway ill get lucky and my 15" kosei k1's will clear an AEM brake kit???
Old Oct 20, 2003 | 09:45 PM
boosted_dc2's Avatar
Default anyway ill get lucky and my 15" kosei k1's will clear an AEM brake kit???
i just ordered these without thinking about clearance issues. I have 18" rh's but for the track i have 15 koseis with slicks, any way thell fit????
Old Oct 20, 2003 | 09:48 PM
P1mpSlap's Avatar
if it's larger than a 10.2" rotor I highly doubt it. Not with the 15s at least.
Old Oct 20, 2003 | 09:58 PM
Default Re: (P1mpSlap)
i dont know what size the rotors are, there the new black ones from aem, the one-peice rotors????
Old Oct 20, 2003 | 09:59 PM
P1mpSlap's Avatar
did you get an upgraded brake kit or replacement rotors?
An upgraded brake kit is going to relocate/push the caliper too close to the wheel.
Replacement aftermarket rotors should be OE size.
Old Oct 20, 2003 | 10:02 PM
thaiphob's Avatar
Nikon!!!
Default Re: anyway ill get lucky and my 15" kosei k1's will clear an AEM brake kit??? (boosted_dc2)
16s are barly gonna clear and you want to try with your 15s? you better be ready to shave your caliper if you want that to happen.
Old Oct 20, 2003 | 10:03 PM
i use my stock calipers and they send me brackets that move it out ward. here check this out if you dont mind.
http://cgi.ebay.com/ebaymotors...27356
Old Oct 20, 2003 | 10:07 PM
P1mpSlap's Avatar
Default Re: (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i use my stock calipers and they send me brackets that move it out ward. here check this out if you dont mind.
http://cgi.ebay.com/ebaymotors...27356</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">KEY FEATURES:
· 100% bolt-on system—no cutting or drilling required
· Every system is ABS compatible
· Rotors are plated/anodized to prevent rust
· Complete hardware kit and comprehensive installation instructions included
· Pads not included. Please see our other auction for performance pads.
· Must use a 16" wheels for this application.
· Black-Carbon finish on the rotor does come off after brakes are installed and used.
Old Oct 20, 2003 | 10:11 PM
yea i know it says that but the other kit (with colored rotors) says 17" an people run 16's so i was hoping that because this one said 16 i could get a way with 15's
DSZ882
Sep 21, 2014 04:08 AM
jdmboyef9
Suspension & Brakes
Nov 2, 2006 03:41 AM
Kaizen
Apr 30, 2003 12:58 AM
turbo Si
Aug 5, 2002 05:01 PM
Altered_Ego
11
May 7, 2002 01:58 PM
