setting number 1 at tdc with a broken timing belt
Old Oct 20, 2003 | 02:02 PM
optoomistic's Avatar
Default setting number 1 at tdc with a broken timing belt
how?
Old Oct 20, 2003 | 04:54 PM
stumpyf4's Avatar
Default Re: setting number 1 at tdc with a broken timing belt (optoomistic)
There is an arrow with up written on each cam pulley when viewed from the driver's side. TDC of number 1 cylinder will be both these arrows pointing up. Number 1 cylinder at TDC at the crank, line up the line on the crank pulley with the triangle on the oil pump. The keyway on the crank will be very close to straight up. Use a strap wrench to turn, take out the sprak plugs to make it easier to turn the crank.
Old Oct 21, 2003 | 03:47 AM
JimBlake's Avatar
Default Re: setting number 1 at tdc with a broken timing belt (stumpyf4)
First, move the crank away from TDC so NONE of the pistons are up at the top. Now you can spin the cams without hitting valves & pistons. After you line up the cams, then put the crank at TDC.
Old Oct 21, 2003 | 06:07 AM
thanks i was just a little confused
i was worried to turn the crank with out turning the cams...
its all good now...on to the crank pully
wish me luck
Old Oct 21, 2003 | 08:11 PM
stumpyf4's Avatar
Default Re: setting number 1 at tdc with a broken timing belt (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">First, move the crank away from TDC so NONE of the pistons are up at the top. Now you can spin the cams without hitting valves & pistons. After you line up the cams, then put the crank at TDC.
Good tip!!
Old Oct 23, 2003 | 05:20 AM
how will i know if the number 1 is a tdc on the compression ....or exhaust.....
if the cams are pointed up does that indicate tdc on exhaust
Old Oct 23, 2003 | 05:30 AM
wcsinx's Avatar
Default Re: (optoomistic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optoomistic &raquo;</TD></TR><TR><TD CLASS="quote">how will i know if the number 1 is a tdc on the compression ....or exhaust.....
if the cams are pointed up does that indicate tdc on exhaust</TD></TR></TABLE>
cams on their mark indicates TDC #1 on the compression stroke
Old Oct 26, 2003 | 09:07 AM
is there a difference between #1at tdc on compression vs. exhaust....when setting the crank...concerning the bottom end...
Old Oct 27, 2003 | 03:48 AM
JimBlake's Avatar
At the bottom end there's no difference. The cams are the only things that make the difference between TDc compression vs. TDC exhaust.
Xemu
28
Apr 22, 2007 01:56 PM
R_type
Jun 6, 2005 06:05 PM
RTW DC2R
May 23, 2005 10:33 AM
Nextelbuddy
Mar 29, 2004 03:38 PM
Nextelbuddy
Mar 29, 2004 11:43 AM
