Comptech RACE Header??
Old Oct 20, 2003 | 10:39 PM
B00ST2nR's Avatar
Default Comptech RACE Header??
Anyone running on one? How is it? These retail for over $900.00 so I'm assuming its quality and gains are good.
How does this header compare to SMSP, DTR, or Header Tech headers??
Comptech B-Series Race Header:
Old Oct 20, 2003 | 10:57 PM
threatcon13's Avatar
New User
Default Re: Comptech RACE Header?? (Skunk2nR)
direct copy of the finest, hytech.
Old Oct 20, 2003 | 10:59 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Comptech RACE Header?? (Threatcon13)
I've heard good things.
Looks to be very good quality as well..... from the pictures I have seen of it.
B2FiNiTY's Avatar
It's not 100% copy. Main difference is the anti-reversion chambers.
I have heard nothing but good things about this header.
Old Oct 20, 2003 | 11:23 PM
Sukebei Oni's Avatar
i heard you don't use a cat with this header. is this true? and will you have a check CEL running this header?
Old Oct 20, 2003 | 11:33 PM
Rhetoric's Avatar
Default Re: Comptech RACE Header?? (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni &raquo;</TD></TR><TR><TD CLASS="quote">i heard you don't use a cat with this header. is this true? and will you have a check CEL running this header?</TD></TR></TABLE>
not if youre running obd1
Old Oct 20, 2003 | 11:41 PM
B00ST2nR's Avatar
Default Re: Comptech RACE Header?? (Rhetoric)
wait... do you use a cat with the SMS, Hytech, Headertech or DTR headers?
Old Oct 21, 2003 | 07:10 AM
Chemicalviper's Avatar
if its a "race" header - then it was not meant for public use - which means its most likely meant for a car at the drag strip or the track ... so it could very possible eliminate the cat, the thing is .. most of the times a test pipe is just in place of where cat could be --- this header does look long tho ...
Old Oct 21, 2003 | 07:29 AM
StyleTEG's Avatar
Default Re: (Chemicalviper)
You can still run a cat, the SMS / Hytech do.
The difference is that the header is much longer than the stock and common aftermarket headers. So where the cat is placed is much further back that it sits in the stock possition.
So, you will have to cut your exhaust and reweld the flange further back. You will also have to use a testpipe or cat, unless you want to use a different flange on your B pipe. The B pipe flange is a three bolt, where the collector flange shown on this header (and all aftermarket headers I have seen) is a two bolt so it can mount up to a cat.
Might as well upgrade to an actual 2.5" exhaust before you spend close to a G on a header. No need to spend that much only to have a bottleneck right after the collector.
Old Oct 21, 2003 | 07:45 AM
JDMHN8's Avatar
Default Re: (StyleTEG)
Looks like it would fit a '92-'93 Integra just fine, with no modification at all...
For once, DA owners get the better deal.
Old Oct 21, 2003 | 09:22 AM
Tweakmeister's Avatar
These, like the other high-end long-tube headers, usually take several months to get once ordered.
I preordered a couple and have them in stock.
If you have any additional questions feel free to let me know.
Old Oct 21, 2003 | 12:53 PM
B00ST2nR's Avatar
Default Re: Comptech RACE Header?? (Tweakmeister)
Hmm... i might actually look into gettin this header then.
Old Oct 21, 2003 | 12:59 PM
Ketone's Avatar
I got a good chance to look at this header this weekend. The quaility is deffinately there . I probably would have gotten this if I did not get TODA
Old Oct 21, 2003 | 01:44 PM
Vtecfool's Avatar
Default Re: Comptech RACE Header?? (Ketone)
Mmm, looks like sex!
Old Oct 21, 2003 | 03:03 PM
n1ek's Avatar
holy crap...look at those welds.
dead sexy.
Old Oct 21, 2003 | 05:19 PM
Audio28's Avatar
Default Re: Comptech RACE Header?? (n1ek)
go with the sms header over the hytech. importbuilders did a dyno comparison and and the sms has higher gains.
Old Oct 21, 2003 | 05:26 PM
fuck honda-tech's Avatar
Default Re: Comptech RACE Header?? (Audio28)
you have to buy an adapter that makes it bolt up its like 100 dollars extra .. very nice system ... turns a nice gold
Old Oct 21, 2003 | 06:08 PM
B U N M A N G O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">Hmm... i might actually look into gettin this header then.</TD></TR></TABLE>
What ever ended up happening w/ that Ebay guy?
I was at a shop last Friday and there was a guy there getting one of these installed on his RSX... he had some O2 sensor simulator thing, and his CEL didn't turn on.
Old Oct 21, 2003 | 06:09 PM
Default Re: Comptech RACE Header?? (epsom salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epsom salt &raquo;</TD></TR><TR><TD CLASS="quote">you have to buy an adapter that makes it bolt up its like 100 dollars extra .. very nice system ... turns a nice gold </TD></TR></TABLE>
skip the Comptech adapter, we ordered a couple and for the money you're better off going with a testpipe that fits your b-pipe size. the flange on the Comptech needs to be bored out for most exhausts.
Old Oct 21, 2003 | 06:45 PM
dom93hatch's Avatar
CARB legal?
Old Oct 21, 2003 | 06:46 PM
Default Re: Comptech RACE Header?? (dom93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">CARB legal? </TD></TR></TABLE>
no, it specifically states on the paper that it's for race applications only.
Old Oct 21, 2003 | 10:40 PM
96dc2's Avatar
Default Re: Comptech RACE Header?? (B U N M A N G O)
Skunk2Nr, didn't you just get a JDM header?
Old Oct 21, 2003 | 10:58 PM
GSRdriver's Avatar
Default Re: Comptech RACE Header?? (96dc2)
Drool...
But I remember your Dad was concered about you passing smog?
Old Oct 21, 2003 | 11:10 PM
B00ST2nR's Avatar
Default Re: Comptech RACE Header?? (GSRdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRdriver &raquo;</TD></TR><TR><TD CLASS="quote">Drool...
concerned yea, but it really doesn't matter. I'll find a way to pass it... hopefully.
Old Oct 22, 2003 | 03:11 AM
slammed_93_hatch's Avatar
comptech's **** is very very nice, ive been there a few times and they are great people with bad *** products been doing it forever too, finally they will be back in the race scene too,
