car wont turn over!
Old Oct 20, 2003 | 10:33 AM
Scharged2000GsR's Avatar
Default car wont turn over!
my car just about to turn on but it needs that extra kick. it might be the injectors not putting gas in to the motor, or spark plugs not firing, or i also come up on a code 20 (ELD). what do you think.
Old Oct 20, 2003 | 10:37 AM
timmy8151's Avatar
Default Re: car wont turn over! (Scharged2000GsR)
First thing you need to check is :
1) Are you getting spark?
2) Are you gettin fuel
Once you check for the above then you can diagnose the problem.
Old Oct 20, 2003 | 12:23 PM
JimBlake's Avatar
Default Re: car wont turn over! (timmy8151)
Spark & fuel.
The ELD just helps maintain steady idle. I don't believe it can prevent you from starting the engine...
Old Oct 20, 2003 | 04:14 PM
monotone485's Avatar
how do you fix the ELD problem
Old Oct 20, 2003 | 06:44 PM
EDoTdc2's Avatar
Default Re: (monotone485)
i had a similar problem check all your fuses especially the IGN or IG fuse
Old Oct 21, 2003 | 03:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monotone485 &raquo;</TD></TR><TR><TD CLASS="quote">how do you fix the ELD problem
</TD></TR></TABLE>Depends on what's wrong...
The ELD is built into the engine-compartment fuse box, it measures the overall electrical load. It could be bad wiring from there to the ECM, or it could be a bad ELD. Check the wiring first, that's probably easier to fix. I guess(?) you can't get the ELD separately, you have to buy a new fuesbox.
Old Oct 21, 2003 | 12:08 PM
Default Re: (JimBlake)
how much do new fuesbox cost?
Bambinoh
Jun 23, 2007 08:50 AM
BALLIN H22 EK
Feb 24, 2006 12:36 PM
McNizzle
28
Dec 14, 2004 02:05 AM
98-0688
Sep 6, 2004 02:13 AM
mystikteg92
Mar 17, 2004 07:55 AM
