DA integra swap
Old Oct 21, 2003 | 01:53 PM
cliff666's Avatar
Default DA integra swap
what is needed to swap a 98 gsr into a 90-93 integra?????? i kno i will need a cable tranny. but what else???? also what is the differences in gear ratios with a cable ls and cable gsr trans???? need help with this idea so please hit me up.
Old Oct 21, 2003 | 02:22 PM
cliff666's Avatar
Default Re: DA integra swap (dragboy)
some one has got to kno this come one help a ***** out...
Old Oct 21, 2003 | 05:46 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy &raquo;</TD></TR><TR><TD CLASS="quote">what is needed to swap a 98 gsr into a 90-93 integra?????? i kno i will need a cable tranny. but what else???? also what is the differences in gear ratios with a cable ls and cable gsr trans???? need help with this idea so please hit me up.
I'll take a stab, but you should really try the hybrid forum.
wiring: if the DA is a 92-93, the gsr wiring harness should plug right into the engine bay harness, but you will have to run wires through the firewall for vtec. You will need an obd1 vtec ecu, preferably a p72 or a chipped p28, but you will not be able to operate the secondary butterflies in the intake manifold with the p28.
axles: use whatever coincides with the tranny you plan on using.
mounts: not 100% on this one, but you'll probably need DA mounts.
You'll need a gsr throttle cable, and firewall bracket.
The DA exhaust will most likely mate to the gsr header fine, but again, not 100% on this one either.
You'll definitely want a cable b-series VTEC tranny, you'll probably fall out of vtec in between shifts with the ls tranny.
Another option is the hasport cable to hydro kit which I *believe* is now available. This will allow you to use the hydro gsr tranny without adding the clutches lines and resevoirs.
Shoot me a PM if you have any more ????
Old Oct 21, 2003 | 06:22 PM
brinks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy &raquo;</TD></TR><TR><TD CLASS="quote">help a ***** out...</TD></TR></TABLE>
I was actually gonna help you before I read that ignorant ****. We are capable of understanding you without the street talk, and it sure doesnt make you look cool, so just save it. You should know damn well not to use the N word when there is even the slightest chance that you might offend someone. I'm not offended personally, I just think you are an idiot and I wont helpya.
Old Oct 21, 2003 | 06:32 PM
mr.beeks's Avatar
Default Re: DA integra swap (brinks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brinks &raquo;</TD></TR><TR><TD CLASS="quote">
I was actually gonna help you before I read that ignorant ****. We are capable of understanding you without the street talk, and it sure doesnt make you look cool, so just save it. You should know damn well not to use the N word when there is even the slightest chance that you might offend someone. I'm not offended personally, I just think you are an idiot and I wont helpya. </TD></TR></TABLE>
we are offended by that!
sorry
Old Oct 21, 2003 | 07:00 PM
91tegrals's Avatar
ah this is the internet not school he should be able to say wat ever he wants, if there is a prob with that kind of language on this forum a mod should adresse it...
Old Oct 21, 2003 | 07:01 PM
91tegrals's Avatar
and 753 basicly answered youre ? but if you need more info check out the g2ic.com...
Old Oct 21, 2003 | 07:05 PM
mr.beeks's Avatar
Default Re: (91tegrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">ah this is the internet not school he should be able to say wat ever he wants, if there is a prob with that kind of language on this forum a mod should adresse it...</TD></TR></TABLE>
help a honky out!!
help a ***** out!
help a spik out!
help a rag head out!
I dont think thats appropiate in here right.
Old Oct 22, 2003 | 02:36 AM
cliff666's Avatar
i am an idiot with actually a 3.2 GPA so whatever u want to say u can kiss my ***. maybe there is a forum about spelling and grammar u can go to. sorry i come from somewhere maybe a lil too urban for u
Old Oct 22, 2003 | 04:38 AM
mr.beeks's Avatar
act like your 3.2 gpa then!
so what good does it do to you to go to school!
you are lucky you are not here in person
I live in queens near the projects and even if you are a black person
and they dont know you well you know what happens next!
"engage your brain before you write"
Old Oct 22, 2003 | 07:19 AM
donnjuan2point2's Avatar
Default Re: DA integra swap (big reds)
be easy big reds he is my boy he is asian and im black he is not at all tryin to be racist or harm anyone dont try to bring other hoods into this cause thas when his team gets in it and u dont want that holla
Old Oct 22, 2003 | 11:29 AM
Mach slo's Avatar
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy &raquo;</TD></TR><TR><TD CLASS="quote">what is needed to swap a 98 gsr into a 90-93 integra?????? i kno i will need a cable tranny. but what else???? also what is the differences in gear ratios with a cable ls and cable gsr trans???? need help with this idea so please hit me up.
If you haven't purchased the DA teg yet, try and buy a 92-93 one. The 92-93 tegs were obd1. This will simplify the install. You will be able to use the existing harness, will be able to use the multi-length manifold solenoid thing if you want, will be able to use all the different good obd1 ecu's, even the p72 that is made for it if you want, you won't have to deal with the stupid 2 o2 sensor problems, and will simplify modding the car as a whole. Basically if you are planning any decent amount of mods you will have to convert to obd1 anyways. Turbo's in particular are very difficult with a obd0 pr3 ecu. As far as trannys I'd go with a ls atleast at first since that is probably what it is already gonna have. Especially if you are planning on significantly increasing its torque in the future. One other thing. DA's are great for swaps, they are cheaper and lighter the the 94+, and unlike the ef's there is no axle or hub issues. The only thing that kinda sucks with the DA's and even the EF's is the front crossmember. It makes fitting a turbo challenging. If you haven't already check out http://www.g2ic.com.
Old Oct 22, 2003 | 11:47 AM
(JON)'s Avatar
Default Re: DA integra swap (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">
hasport does make the kit but unfortunately it wont work for da's. there isnt a proper tranny mount that lines up correctly, unless you fabricate one!
Old Oct 22, 2003 | 12:09 PM
743power's Avatar
Default Re: DA integra swap (DaStyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaStyle &raquo;</TD></TR><TR><TD CLASS="quote">
hasport does make the kit but unfortunately it wont work for da's. there isnt a proper tranny mount that lines up correctly, unless you fabricate one!</TD></TR></TABLE>
Well doesn't that just suck.
Old Oct 22, 2003 | 12:51 PM
cliff666's Avatar
Default Re: DA integra swap (donnjuan2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donnjuan2point2 &raquo;</TD></TR><TR><TD CLASS="quote">be easy big reds he is my boy he is asian and im black he is not at all tryin to be racist or harm anyone dont try to bring other hoods into this cause thas when his team gets in it and u dont want that holla</TD></TR></TABLE>
DRAG1320 fellow member
Old Oct 22, 2003 | 01:42 PM
mr.beeks's Avatar
a homo net thug.
figure that out???
Old Oct 22, 2003 | 02:02 PM
cliff666's Avatar
whats ur deal starting **** bro? i grew up talking a certain way that doesnt mean my intelligence is lower, i get it u just want to try n be funny and flame icic too bad u the only one thought it would be "cool" to try n correct my grammer this time.
Old Oct 23, 2003 | 03:07 AM
Happyman's Avatar
lol internet gang fights. Good times.
Old Oct 23, 2003 | 05:47 AM
Claborn's Avatar
hey big red. [urban twang]im black too and u offended me by sayin WE cant say wut ever WE want so stick that in ya tail pipe..... *****![/urban twang]
[white persona]anyway, to answer your question, http://www.g2ic.com would be a lot better place to look, because it's all about the 2gens and theres tons of people who have done the H22 swap and surley the gsr swap. hope this helps![/white persona]
Old Oct 23, 2003 | 08:09 AM
97itr86's Avatar
Default Re: (Claborn)
If you have a 92-93 you will need an OBD 1 dohc vtec distributor, cable tranny and flywheel, OBD1 ecu, the stock axels will work, and you will have to wire up vtec if you don't buy a 92-93 gsr.
Old Oct 23, 2003 | 09:07 AM
Mach slo's Avatar
Default Re: (97itr86)
Last I checked obd2 and obd1 distributer are the same. thats why you can run a obd2 car with a obd1 ecu using a harness adapter. If you need to you can even use the ls distributer that is already on the b18b that is in it, just have to cut the one leg off of it that is in the way of the vtec solenoid. Use existing axles and intermediate shaft.
Old Oct 23, 2003 | 09:28 AM
97itr86's Avatar
Default Re: (Mach slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach slo &raquo;</TD></TR><TR><TD CLASS="quote">Last I checked obd2 and obd1 distributer are the same. thats why you can run a obd2 car with a obd1 ecu using a harness adapter. If you need to you can even use the ls distributer that is already on the b18b that is in it, just have to cut the one leg off of it that is in the way of the vtec solenoid. Use existing axles and intermediate shaft.</TD></TR></TABLE>
When you cut the leg off the distributor it is good only for temporary use. Everyone I know that has done this had problems with sputtering after a while. Just buy the right distributor.
futurefastguy
Aug 31, 2006 12:13 AM
95lscivic
Aug 16, 2005 07:03 PM
crazy eyez killa
Jan 26, 2004 03:02 PM
