one more question about coilovers
Old Oct 22, 2003 | 11:00 AM
aznfab's Avatar
Default one more question about coilovers
If i raise my coilovers all the way up.....will it reduce some bouncyness?
Old Oct 22, 2003 | 11:12 AM
631 Teggy's Avatar
Default Re: one more question about coilovers (aznfab)
No... Your just pushing the spring up... The shock will stay at the same pressure, and the spring will stay just as stiff...
What you will do, is lengthen the susspension travel... And give yourself a higher center of gravity...
Old Oct 22, 2003 | 12:04 PM
deepgreengsr's Avatar
Default Re: one more question about coilovers (631 Teggy)
depends, is it bounchy becuase you are hitting the bumpstops? or cus the strut spring combo is wrong? if you are hittting the bump stops and its bounceing then yes you can raies it up and no more bounce.
Old Oct 22, 2003 | 12:39 PM
tweak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznfab &raquo;</TD></TR><TR><TD CLASS="quote">If i raise my coilovers all the way up.....will it reduce some bouncyness?</TD></TR></TABLE>
actually it will..... i've done it on my car used to have the thing dumped and it bounced like crazy but then i was bottuming out to but once i raised my front a inch or two it wasn't as bad...
- Dave
matryx
Suspension & Brakes
10
Aug 24, 2008 09:35 PM
jeison
Mar 4, 2007 09:14 PM
impr323
Apr 28, 2005 06:26 PM
sjteg
Suspension & Brakes
Jan 12, 2005 10:49 AM
BrandonClaps
25
Aug 11, 2002 10:47 PM
