B16 swap wiring issues
Bought a running b16a jdm swapped 89 crx that looked terrible so I took it apart to fix everything. Like down to just the chassis. After paint and all I'm installing everything. There is an issue with the wiring though. It just won't work. With key in or out of the ignition the dash displays the oil and battery light. Headlights won't come on even and nor do the brake lights. Main grounds are grounded and all fused are fine in both boxes. Trying to starting the car does nothing, even to the dash lights that just stay on. None of the ac, heater, blower unit stuff is in the car. Besides the couple of dash accessories everything is hooked up. Have ecu disconnected till I get this figured out.fuel pump does not prime (chance the main relay is just bad though and have a new one on the way). Can't get the ignition cylinder to start the starter but it does turn the engine when hotwiring it at the starter. Any help is appreciated very much right now.
Freemananana
09-11-2014 12:13 AM
vtechjunkie
16
01-06-2010 07:44 AM
