Door rattle
Door rattle
What's the easiest way to get my door to stop rattling? Not fishing here. I took my pane off my passenger side door and found the rattle. It's the two rods that operate the interior door gandle. They're rattling where they hook and pin into the parts that work the door opening mechanism.
I tried lubricating them but figured it wouldn't work because it's not a squeak. Anyone have any creative suggestions. I can't imagine I'm the first ef owner to have this problem. Lol.
Re: Door rattle
Well I removed my panels 4 times, trying various methods and listening for vibration. It's largely due to my innovative motor mounts and b series swap. I have some torsion vibration to say the least. Lol. I have a couple other rattles I'm working on. I also bought the car with some poly bushings already installed. I will be ordering rubber ones very soon.
Re: Door rattle
Good to hear. I've used foam in the past for similar fixes. It can be attached to a surface and sort of "push" on whatever is rattling. It has enough springyness to keep contact, but won't push on it hard enough to distort or bend anything.
Okay I figured it out. The metal rods that connect inside the door near the locking mechanism. It hooks inside a plastic bushing. That bushing in turn connects to the door mechanism. The gap was in between the plastic and metal of this connection. After trying several things including foam under the metal rods, which partially worked, I decided to take a chance. I took needle nose pliers and reach inside the door. The plastic bushing was rattling in the metal clasp. I grabbed around the metal clasp, squeezing it as tight as I could and binding against it slightly. This closed the metal tight against the plastic bushing. NO MORE RATTLE!!!!
Now I would say that depending on a few and condition, this process could easily snap the plastic bushing....... in which case you're screwed. But if you hate that incessant rattle forcing you to turn the radio up, then perhaps this plan will help.
m.glisson003
08-07-2011 12:36 PM
