Help with 90 CRX hazards and turn signals. - Honda-Tech - Honda Forum Discussion
Old 04-14-2016, 09:02 PM
Default Help with 90 CRX hazards and turn signals.
I recently purchased a 90 CRX but my hazards and turn signals do not work. They don't even light up on the dash. I've checked all my fuses and they all seem fine. Any idea why they aren't working?
Any help is appreciated guys.
samwam323 is offline
Old 04-15-2016, 08:03 AM
KILLAB17VTEC
acmoc's Avatar
Default Re: Help with 90 CRX hazards and turn signals.
Is the hazard switch connected?
acmoc is offline
Old 04-15-2016, 09:09 AM
fcm
Old Fart
fcm's Avatar
Ditto the above^^^, both hazard and signal lights power goes through the hazard switch.
If it is plugged in, you will need to test the switch, if good, the problem is most likely the hazard/signal light relay. 94
fcm is offline
Old 04-15-2016, 11:21 AM
Yeah it is connected I took apart my dash to check and it is. How can I test my switch?
Old 04-15-2016, 02:33 PM
Ok I replaced my switch and still nothing where is the relay located so I can try to change it.
Old 04-16-2016, 08:32 AM
fcm
Old Fart
fcm's Avatar
Should be upper left of under dash fuse box, 3 pin relay, one of the pins, [top] in the socket should be 12V+ when signal or hazards are turned on, one will be a ground at all times, [bottom] the 3rd one, [left side] is the output, supplying power to it will turn on the signal lights, [left or right] is signal light switch is on, and hazard switch off, both sides will turn on if hazard switch is on. 94
fcm is offline
Old 04-16-2016, 03:43 PM
Thank you so much man. Switching the relay fixed my problem. Saved me money by not going to a electrical shop so thank you so much again.
h23ajdmlude
01-17-2010 03:28 PM
dustyb20
03-11-2009 03:09 PM
moleodonuts
09-13-2005 02:00 PM
Home Skillet
08-16-2005 01:27 PM
deetz84
16
05-30-2005 06:49 PM
Quick Reply: Help with 90 CRX hazards and turn signals.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
