15x5.5 45mm?
15x5.5 45mm?
New to this...just picked up a 91 si hatch.
In need of some new wheels/tires. Wondering how well 15x5.5 with 45mm offset will fit?
Found a great deal (basically free) on these wheels off an insight. Not sure how they'll look yet but willing to give it a try if they'll fit. Also, what would be best tire size?
Re: 15x5.5 45mm?
They'd fit great. A tire alternative to keep your overall stock diameter nearly dead on is 195/50-15.
205/50/15 is also very close but would likely balloon a bit too much on a 5.5" wheel.
185-60R14 vs 195-50R15 vs 205-50R15 - Tire and Wheel Plus Sizing | Tire Size Calculator
Re: 15x5.5 45mm?
I would give willtheyfit.com a try, they let you visualize your old setup vs. your new setup
If you have Si 14" wheels, here's what your new setup will look like in comparison (no real change, see diagram on right side of page)
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
If the wheels were quite a bit different, the old wheels would be orange and your new wheels would be green. In this case, all the lines overlap each other.
EFB055
Re: 15x5.5 45mm?
NONKonformyst
01-11-2003 08:08 AM
