Turbo Coolant Lines, which fitting is this?
Old Jan 31, 2015 | 01:33 PM
Nisif's Avatar
Default Turbo Coolant Lines, which fitting is this?
Just ordered a new turbo and I'm looking to run my coolant lines on a LSVtec from the coolant bleeder valve next to the vtec solenoid and then route the outlet to the block heater plug. Does anyone know which type of fitting screws into the bleeder valve? Running 6an lines...
Here's a pic for reference:
http://i299.photobucket.com/albums/m...d/IMG_9077.jpg
Old Jan 31, 2015 | 04:42 PM
TheShodan's Avatar
Moderator
Default Re: Turbo Coolant Lines, which fitting is this?
you'll more than likely have to find out the pitch and size of the bleeder valve screw (by removing it or check your helms manual to find its size) then find a male-to-male adapter fitting to fit.
Old Jan 31, 2015 | 09:23 PM
wantboost's Avatar
Who is Mr Robot?
Honestly using a fitting in place of the front water fitting on the block then to the bleed would make for an easier and cleaner install.
Old Feb 2, 2015 | 09:29 PM
Nisif's Avatar
That's exactly how I'm routing it. Bleeder Valve to turbo, then turbo to front freeze plug on the engine block.
FYI, The bleeder valve has a M10 x 1.25 thread size/pitch. I ran a tap through it to confirm.
AlAddiN|502
Sep 12, 2010 09:18 PM
91crxturbo
Aug 22, 2007 03:28 AM
Topdawgg
Feb 12, 2007 08:41 PM
2000vsm
Aug 24, 2003 07:31 PM
CalvitoSol
Jun 9, 2003 01:50 AM
