To get hondata CPR, or not. Questions
Old 03-27-2015, 12:39 PM
supersilverdc2's Avatar
Default To get hondata CPR, or not. Questions
Hi,
Anyone running a hondata CPR setup? Any major difference? Is it really worth the $400 ?
CPR = coil pack retrofit for those who don't know.
Old 03-27-2015, 01:41 PM
mtber's Avatar
Default Re: To get hondata CPR, or not. Questions
Originally Posted by supersilverdc2
Hi,
We have several cars running cpr systems.
What engine setup do you have?
What fuel are you running?
How much power will you be making?
Old 03-27-2015, 02:01 PM
Fully built lsvtec turbo
Borg warner s360
Sheepey top mount
Skunk2 rods
Rs machines block
Supertech valve train 85lb springs
Skunk2 pro1 cams
Supertech pistons
Looking for 400-500hp on street with boost by gear setup.
Gsr trans with ls 5th (considering lsd)
Old 03-27-2015, 02:20 PM
Moderator
TheShodan's Avatar
No.. not necessary for that power goal and use. An enhanced stock ignition at the most should ever be needed. (ICM bypass by Turbo LS, Mallory digital ignition box, and external coil), or even start with an aftermarket Accel IC for basics.
I'd you're changing over for the sake I'd found so, that's one thing..But not a requirement. Check to make sure you're ok first after running, then see of you need changes
Old 03-27-2015, 02:45 PM
mtber's Avatar
Borg warner s360
Sheepey top mount
Skunk2 rods
Rs machines block
Skunk2 pro1 cams
Supertech pistons
For 500 whp the oem honda distributor/coil/cap/rotor/plug wires will work just fine on pump gas.
Keep in mind you will need FRESH oem (not aftermarket) ignition components. Not components that are old with a ton of use.
I have had customers making 400-500 upgrade to CPR because their ignition components were old & needed replacing & they wanted COP technology.
It works great.
Old 03-27-2015, 04:02 PM
Moderator
TheShodan's Avatar
Exactly
henchie
01-11-2012 11:58 AM
LilTeggy2011
Engine Management and Tuning
11
06-01-2010 04:51 PM
Hoosier Daddy
10-23-2003 04:52 AM
T-Blaze
06-04-2003 04:19 AM
Sh4rky
03-14-2003 03:56 PM
Quick Reply: To get hondata CPR, or not. Questions
