Built LSV Identify Tick/Knock
Old Mar 15, 2015 | 08:49 AM
SergieL's Avatar
Default Built LSV Identify Tick/Knock
Ok guys I have this ticking or more like knocking sounds on light acceleration. At idle it sounds fine, but when I start accelerating it starts at about 2k rpms and is on to about 5-6k rpms and thru out it doesn't get louder but stays at about the same volume. When I let go of the peddal at 6k rpms and let it fall down to lower rpms it never ticks, only on acceleration. Also, if I'm driving at about 25mph and shift into 5th gear and press the peddal down, it doesn't tick. So it's always under no load acceleration. Vibration? I'll upload a video soon. Thanks for your help.
Old Mar 15, 2015 | 08:56 AM
SergieL's Avatar
Default Re: Built LSV Identify Tick/Knock
Here's a video
https://*******/8RT5
Old Mar 15, 2015 | 09:25 AM
turbohatch96y7's Avatar
Sounds like rod knock buddy.
Check your valve lash first tho.
Do you have a oil gauge?
I wouldnt drive it anymore
Old Mar 15, 2015 | 09:28 AM
SergieL's Avatar
Oil gage reads fine, I don't think it would be a rod knock because like I said, it's fine at idle. Id doesn't get louder as the rpms increase and its golden eagle rods
Old Mar 15, 2015 | 09:33 AM
Piston to valve contact?
Old Mar 15, 2015 | 09:38 AM
SergieL's Avatar
I don't know. Car runs fine as always. The strange thing about this is that it stops when in gear I let go of the gas pedal and the noise stops
Old Mar 15, 2015 | 09:47 AM
LTCxD2B's Avatar
I would start with a long screw driver near the oil pan and work my way up... I had a friend crack a sleeve and it sounded like piston slap which makes sense
Old Mar 15, 2015 | 09:54 AM
SergieL's Avatar
This motor is sleeved my golden eagle and it drives just fine. Cracked sleeve would have compression loss and drive like crap, mine drives fine
Old Mar 15, 2015 | 09:59 AM
SergieL's Avatar
My timing belt is loose. Everytime the noise comes on, I see the timing belt just start flapping all over. And when the knock stopes than the timing belt rotates fine.
Old Mar 15, 2015 | 12:02 PM
viper_boy403's Avatar
Sounds like sticking LMA's. If you're still running piston style, ditch them for the spring-type.
Old Mar 15, 2015 | 01:11 PM
SergieL's Avatar
Yes it's piston style LMA's, I pulled the valve cover off and the valve clearance is .010-.011 clearance on intake valves. They should be at .06-.07. I'll adjust it soon and will see how that goes
Old Mar 15, 2015 | 01:13 PM
SergieL's Avatar
And the knock is coming out of the intake manifold, so hopefully that's the reason
Old Mar 15, 2015 | 01:27 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What cams are you running?
Old Mar 15, 2015 | 01:28 PM
SergieL's Avatar
Buddy club spec 3's
Old Mar 15, 2015 | 03:23 PM
SergieL's Avatar
I just adjusted the valves and still doing it. Knock comes out of the cylinder 3 because when I lift the spark plug wire out of it, it stops making that knock
Old Mar 15, 2015 | 04:02 PM
KevinEF7's Avatar
Sure sounds like a bottom end knock to me
But you dont seem to want to hear that
Pull the oil pan
Old Mar 15, 2015 | 04:31 PM
SergieL's Avatar
Pull the oil pan
Yup, most likely bottom end, no other explanations anymore. Switches the plugs around to see if it was misfiring and sounds about the same. Might be a bearing. Motor is build so I dont know if golden eagle rods would start knocking at only 418whp and Pistons are SRP 11:3:1
Old Mar 15, 2015 | 04:39 PM
Detonation will pound out those bearings.
Nothing to do with the rods
Old Mar 15, 2015 | 04:44 PM
SergieL's Avatar
My plugs are worn out, I had issues starting my car due to those plugs and sometimes I smelled gasoline when I drive.
Old Mar 15, 2015 | 05:06 PM
KevinEF7's Avatar
And $10 worth of plugs was out of the budget?
Old Mar 15, 2015 | 05:08 PM
SergieL's Avatar
Didn't feel like changing them, had enough of other work that got me tired of this car.
Old Mar 15, 2015 | 05:15 PM
KevinEF7's Avatar
Your money, but $10 and literally 5 minutes work is worth maintaining a sleeved fully built motor to me
Old Mar 15, 2015 | 05:18 PM
SergieL's Avatar
Agree, I doubt that it was the reason for my problem. I've been beating on the car lately pretty bad
Old Mar 15, 2015 | 06:25 PM
m4xwellmurd3r's Avatar
Beating on a car with worn out plugs is a good way to ruin a motor. Couldve detonated from am inconsistent spark or something and raped your bearing.
Old Mar 15, 2015 | 06:28 PM
SergieL's Avatar
Could be anything for any reason but don't want to get into that. will pull the pan In a week and see what's going on
