turbo set up help
Old Mar 26, 2015 | 07:23 PM
deeboii2014's Avatar
Default turbo set up help
I'm trying to find out where i can get the vacuum quick fittings and lines and also where would i get a reducer for the oil return line off the turbo to the oil pan because i plan to use it for daily driving
Old Mar 27, 2015 | 09:03 AM
Tegger93's Avatar
Default Re: turbo set up help
McMaster-Carr
Old Mar 27, 2015 | 05:14 PM
wantboost's Avatar
Who is Mr Robot?
b&r fittings.
why would use use a reducer on the return line? it needs to be as large as possible
Old Mar 27, 2015 | 05:28 PM
Its a percision 7667 turbo still no restrictor
Old Mar 30, 2015 | 09:53 AM
Tegger93's Avatar
He's right. IF you do need a restrictor it needs to be upstream of the oil inlet on the turbocharger center section
Old Mar 30, 2015 | 11:48 AM
TheShodan's Avatar
Moderator
If their using a "big shaft", no. Calling Precision won't help you. You'll need to see other setups similar to yours and see what they're using. I might have an idea, but I'd rather you check out other systems, than me be wrong..
Old Mar 30, 2015 | 11:54 AM
Dark_Teg's Avatar
It seems odd to me that you have built a ride that can utilize this ginormous turbo but ask such basic questions.
Old Mar 30, 2015 | 06:38 PM
TheShodan's Avatar
Moderator
More than likely because he bought it for a "Steal-of-a-deal"..
Old Mar 30, 2015 | 10:48 PM
Its my first turbo build if you'd like I can post some pics up tomorrow its half way done
Old Mar 31, 2015 | 10:05 AM
Tegger93's Avatar
I'd be interested in seeing some pics
Old Mar 31, 2015 | 02:52 PM
Its a JDM b18cr complete swap precision 6776 turbo turbotrix custom top mount headers
Old Mar 31, 2015 | 02:53 PM
roachsboosted16
Oct 3, 2010 10:24 AM
Boostinb20!
Mar 27, 2009 07:06 AM
daluv
Jul 31, 2008 12:20 PM
slo_crx
Oct 12, 2004 05:51 PM
ZCHF
Mar 14, 2003 12:38 PM
