full size Radiator in turbo integra FIT?
ok guys i need a quick answer before i order a new radiator, will a ful size radiator fit in my turbo integra
i am running a a/c compatible ramhorn manifold, i assume bc itis designed to keep a/c componets that a full size would work, but i need to be 100% sure,
has anyone had experience with this my big concern is that the wastegate might hit or be in the way, i a running a BRMS a/c compatible mani that has the WG slightly cocked to the right coming off manifold
i am pressed for time since i have to order first thing in the am so it will be here on friday andi can get my daily bad on the road. any help or knowledge would be greatly appreciated
thanks in advance !!!!
Re: full size Radiator in turbo integra FIT?
There are options to do a larger radiator. I run a Volkswagon Scirocco radiator which is able to tuck into the rad support enough to clear most manifolds. It's also a dual pass eadiator which cools more efficiently.
thanks for the suggestions and inputs guys.
I think my wastegate would have problems clearing since I can barely get my hand in between WG and Rad support
It fits I had jdm front integra with full size radiator, full size condenser (ac worked), ramhorm 3inch down pipe, gt3540s it will fit but its a bitch to work on!!
dafuzzbudd
12
10-03-2006 09:41 PM
