B18c1 supercharged build
So I bought a 2000 integra with a gsr in it and ive been modding it up. The previous owner had the block bored over and put some lower compression pistons in it because he was planning on spraying it. I want to buy a sc for it but want to know if it would be good for a dd. And what kit should I get ? Any other info will help.
this is what I have done to it
Ported and polished head
-Supertech valves, retainers, and springs
-Ctr cams
-Skunk2 intake manifold and throttle body 70mm
-Tri-Y headers
-straight piped from 2.25 following 2.50 with burnout exhaust
-Aem ram air intake
-Ctr cams
-Tri-Y headers
-Aem ram air intake
SC Options:
Roots Blower (JRSC):
Pro's: Bolt on power
Keep all your accessories (AC, PS)
Carb. Legal
Reliability
Boost through entire rpm range
Con's: Heat
Finding a complete kit
Wear and tear of older kit's
Sourcing replacement parts
Centrifugal Blower (Rotex, ProCharger):
Carb legal
Run higher boost
Intercooling compatability (AirtoAir)
Con's: $$$
Boost comes at higher rmp
Loose accesories (I think A/C, but might be PS)
I'm not claiming to be the Steven Hawking of SC, but hope this helps a bit.
What supercharger should I get? : SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
Carb. Legal
Reliability
Con's: Heat
Carb legal
Run higher boost
Con's: $$$
