B16A3 turbo set up help
I want to do a stock turbo b16a3 with out rebuilding motor , what do you guys recommend on doing? not planning on too much power .. 300hp max .. can I do it with completely stock engine?
With the addition of arp head studs, and a good TUNE, 300whp is not a problem on a stock engine. Go ahead and read the FAQ sticky at the top of this forum. It is full a really good info if you are just starting to learn about forced induction.
you don't even need the ARP studs for that power. make sure you get the correct equipment, and standard maintenance checks of oil, fuel, clutch, etc. Spend the money on a good clutch over the ARPs. for 300whp, no need to do it.
khmerxnuttyxb
Jul 3, 2021 04:41 PM
